I have a 1997 with a glass top. On the inside of the glass it has a film with the dot pattern that blocks some of the sun but not all. Does anyone make a custom fit solid film?
Best thing for the top is static cling dot matrix shade. I've posted about it in the past. You can buy a sheet on eBay or Amazon. A good tint shop will not tint it for you since it can damage the top.
It already has the dot matrix film. Still to much heat coming in. We have had record heat this summer (Florida).
Just got my RPI Headliner in. I installed it but it does not lay flat at all. Rounded way out in the middle. For you guys that have it is this normal? Guess it does not hurt anything, just thought it would lay flatter. Quality is real nice.
I wouldn't say that it sags but at the same time I wouldn't say it perfectly flat up against the glass either. To me it looks what I would consider normal when I look in the car.
My car had one from MidAmerica when I bought it. Never sagged, even when I added leather upholstery to the surface. It used stiff plastic tabs that forced their way between the glass and the weatherstrip.
At it's lowest point I might have an inch between the headliner and the glass. Visually it looks fine so it doesn't bother me.
I wonder if you have the plastic tabs of the headliner engaged into the frame as far as they will go?
they sort of ‘self force’ themselves into place. I find it easier to install with it on my workbench rather than fight with it overhead.
If the gap is only an inch I wouldn’t get excited over it either.
