[Z06] Brake Change time need advice PLS
Baer EradiPlus kit for the C5/Z06 $1,099.00
The kit consists of 12.75 two piece front rotors (stock size) and 14' two piece rear rotors (plus size). This kit is a direct replacement and will work with any C5/Z06 Corvette with stock wheels. A fitment check is recommended with aftermarket wheels. EradiSpeed rotors come standard with slotted, cross-drilled and zinc washed surfaces that deliver brilliant race quality function and appearance.
Baer Eradispeed Rotor Set $749.00
Baer is proud to introduce their new line of EradiSpeed™ direct OE replacement performance rotors. Featuring LITE™ (Low Inertia / Thermally Efficient) Technology, EradiSpeed™ rotors feature lightweight aluminum hats, or Baer's exclusive (patent pending) hat/hub combinations, and employ severe duty, curved, directional vane (vented), slotted, crossdrilled and zinc washed rotors, for brilliant, race quality, function, and appearance. These are the World's first direct OE replacement rotors to deliver real and measurable performance gains. By eliminating the weight at the center of the stock iron rotor, Baer is able to cast the new rotor with more mass in the "fire path", where the pads contact the rotor, allowing substantially more heat to be absorbed into the rotor. Balancing and heat-treating, coupled with the increased pumping efficiency of directional vanes (vents), ensure that EradiSpeed™ rotors deliver substantial performance benefits. Something that OE or cosmetically altered OE rotors simply can't do. Note: Fronts are a two
piece design. Rears are a one piece design.
I want Baer bec of the anti warpage warranty. So any suggestions.
and is this the best price or can i find a better price? and how much will the brake pads cost and what kind of brake pads should i get with these ?
Thanx alot guys for your input.
[Modified by MrKool, 6:11 AM 11/14/2002]
Randy Goss :cheers:
:D: Oh, and most magizines have shown the Z06 to have the "shortest Stopping Distance" from 60 to ZERO of the cars tested in 2002. That does include testing Turbo Porsches....lolol
[Modified by trumper Z06, 9:03 AM 11/17/2002]
