Convertible top replacement
Old Oct 19, 2019 | 12:55 PM
Rtp's Avatar
Rtp
Default Convertible top replacement
I’m getting ready to replace the convertible top on my 99. Which supplier is better, Robbins or Kee, prices are fairly similar.
thanks
Old Oct 19, 2019 | 04:29 PM
GroundFlyer's Avatar
GroundFlyer
St. Jude Donor '19
I had a Robbins tan top installed in July and fit and texture are as original. Very satisfied with it. Good luck with your research.
Old Oct 19, 2019 | 08:58 PM
00Midnight's Avatar
00Midnight
I just checked into this with a #1 car upholstery shop in Seattle. They said only go with Robbins or EZ On. Their experience with other tops, while good quality, require many more man hours to fit properly.. Check out tops online
Old Oct 20, 2019 | 08:49 AM
Rtp's Avatar
Rtp
Old Oct 20, 2019 | 02:47 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
When the time comes for my 2004, I plan on a Robbins top.
Old Oct 20, 2019 | 06:50 PM
Rtp's Avatar
Rtp
Thanks, given the answers I’ll be ordering the Robbins top
Old Oct 21, 2019 | 11:13 AM
waupachino's Avatar
waupachino
I went with Robbins for mine and have been happy. GAHH is also a very high quality replacement. The newer tops, I believe 01 plus are thicker and quieter. I believe the material that I went with was the Twillfast 2.
Old Jul 7, 2020 | 03:04 PM
woodsdesign's Avatar
woodsdesign
I am currently in the middle of installing a Stayfast Top on a 61. One of the most common problems is undoing a previous bad install. People that don't know what they are doing have a tendency to glob a lot of glue on it..Especially on the rear ws area. This has to be removed to install it the right way.
There are usually a lot of broken/stripped screws to replace. I also take off the front edge of the side frame rails to straighten them out.. It is very common for them to be bent. Other parts of the frame also had to be straightened.
By far the most time consuming part of the install is proper aligning of the frame. That can be very frustrating.
And, this is a very nice one owner car.
Old Jul 7, 2020 | 04:07 PM
MSG C5's Avatar
MSG C5
For those of you have installed a new top for your C5, did you also order and install a new headliner and is that separate from the top?
Old Jul 7, 2020 | 06:37 PM
woodsdesign
They are sold separately. I have found that a headliner that looks pretty good with the old top many times looks old with the new top. I would look at the existing headliner very closely before reinstalling it. jmo
Old Jul 7, 2020 | 08:30 PM
Rtp's Avatar
Rtp
Thanks I did go with Robbins just waiting for the install.
Rory
To Convertible top replacement
