build threads?
Old Oct 28, 2019 | 05:41 PM
dusterbd13's Avatar
dusterbd13
Default build threads?
is there a specific place on the forum for build threads? I have a pretty radical build I have taken over, and figured id share just what is going on....
it IS a c5, so no worries there. it just doesn't look much like one at the moment.
Old Oct 28, 2019 | 05:50 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
You’re in the right place, right here brother.
Old Oct 28, 2019 | 06:44 PM
dusterbd13's Avatar
dusterbd13
Will do!
didn't know if there was a better place, so thanks!
there will be a TON of questions. ...
Old Oct 30, 2019 | 05:41 PM
_zebra's Avatar
_zebra
either here or performance results, typically.
FI section if you're feeling that frisky
Old Oct 30, 2019 | 05:52 PM
dusterbd13's Avatar
dusterbd13
I had put it in here. It was here for a total of about 15 minutes before a moderator moved it due to no longer having a Corvette body on it. just a Corvette drivetrain, chassis, transmision, frame, and interior.
I guess if you want to follow along for a 700 rear wheel horsepower low budget build work then whatever section it got put in. Its labeled darth nader
Old Oct 30, 2019 | 06:19 PM
USAZR1's Avatar
USAZR1
If others want to see the OP's Corvair project, here's a link to the thread. Definitely not a C5 Corvette build thread, though.
https://www.corvetteforum.com/forums...nge-build.html
To build threads?
