I haven't been able to find a definitive answer to this, but is there any way for the dashlights to stay illuminated when driving during the day? For instance, if it's overcast or I'm driving on a back road with trees lining both sides, I can't see the guages all that well. Everything lights up okay when the headlights or parking lights are on, but it would be nice to have the dash backlit during normal daylight driving.The HUD is some help but is there a setting or something I'm missing for the dashlights?
Great question! Sorry I have no answer, but appreciate the issue. My old eyes could use the extra contrast and illumination also. I have run with the parking lights on under some conditions.
Subscribed in hopes some one has the wiring diagrams or experience with this.
New 03 Z owner here and I noticed that when I turn the key onto start the motor the parking lights come on ( book calls them daytime driving lights) and then I turn the light switch stick 1 click and the dash lights come on without moving the stick another notch forward to turn the headlights lights on. Maybe that's on an 03 what year is yours? and don't forget the brightness/dimmer adjustment switch.
You are correct. The headlamps don't come on but they do come up, which is what I'm trying to avoid..
then you have another issue going on. Either your stalk or headlight control module or something else. One click is only parking lights. Headlights should neither come up nor come on.
Okay. I'll retry this. It could be that I turned the headlights on and then back to parking lights to replace a bezel and work on a bump stop and got the impression that the headlights stayed up with the parking lamps only on. If just going one click to parking lamps gives me dash lights without the headlights being exposed, problem solved. Thanks to everyone for your input.
Originally Posted by STRMLNE
Just turn the stalk one click. Dash lights come on. Headlamps won’t.
I agree. When you just turn on the parking lights, the headlights should stay down. That's the way my '03 worked.
To piggy back, I've noticed if you have the headlights on, then turn the stalk one click back to parking lights, the headlights will stay up but turn off. Mine work the same way as everyone else has mentioned otherwise
My headlights are still popping up in the park light mode so I must have another issue. The right headlight has the dreaded grinding noise after closing and I read somewhere that this could cause the functionality of the system to not operate properly. I guess I have the "gear in the headlights" look at this point.
if it's dark enough to not read your gauges clearly, you need your lights on anyway, so turning on the parking lamps at a minimum is a great idea.
i never realized until i rented a new-fangled car earlier this year how much those constantly-lit dash screens drain your situational awareness. i always wondered how all those idiots drove around at night with their lights off & didn't notice... now i see that between the DRLs & the instruments always being lit, they just can't otherwise tell without looking at the switch.
