[Z06] Water on Windshield?
Old Nov 14, 2002 | 07:39 PM
GregZO6's Avatar
GregZO6
7th Gear
Default Water on Windshield?
I'm having an unsually problem. Whenever I accelerate very fast, really going thru the gears I get a small amount of water on the drivers side of the windshield. Its coming from under the hood. At first I thought it was residual water from washing the car. However, even weeks after the car gets wet I still have the problem. And it's not fluid from the radiator, Its clear. Does anyone else have this problem? :confused:
Old Nov 14, 2002 | 08:18 PM
GTs 58's Avatar
GTs 58
Default Re: Water on Windshield? (GregZO6)
I haven't noticed this happening to mine yet. It's windshield washer fluid leaking out.
Old Nov 14, 2002 | 08:55 PM
jw02's Avatar
jw02
I have noticed the same thing when drag racing. I'm not sure where its coming from. Anyone else? :confused:
Old Nov 14, 2002 | 09:21 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: Water on Windshield? (jw02)
It's washer fluid, during hard acceleration it makes enough fluid pressure to force a little out the drivers side squirter.
You can fix it but it takes a Ford vacum check valve to do it, install it on the fluid out line under the washer bottle arrow away from the bottle and its fixed. :smash:
Old Nov 14, 2002 | 10:01 PM
pridnjoy's Avatar
pridnjoy
Default Re: Water on Windshield? (RPO_Z06)
Congratulations! You have now seen what your ZO6 is able to do.
Enjoy :yesnod:
Old Nov 14, 2002 | 10:30 PM
jw02's Avatar
jw02
RPO_Z06,
Thanks for the info!
Old Nov 14, 2002 | 10:37 PM
Z06 Quin's Avatar
Z06 Quin
Default Re: Water on Windshield? (Speedy-Gonzalez)
I don't drive my 2003 Z06 hard...
SHAME ON YOU!!!! :nono:
:jester :jester
Old Nov 14, 2002 | 11:01 PM
ZO6LS6's Avatar
ZO6LS6
Greg,
this will eventually discolor your hood felt.........
Get a turkey baster, and remove approx 1/2 of the washer fluid...........
Do not run it empty........or it will freeze up, and ruin your washer motor........
My '01, used to give my car a bath in every gear( thru 4th) at WOT........... ;)
Old Nov 15, 2002 | 09:47 AM
ZO6Les's Avatar
ZO6Les
Default Re: Water on Windshield? (ZO6LS6)
I did the same thing, removed 1/2 the fluid with my turkey baster (which doubles as the clutch and break fluid removing tool as well), no more problems with WW fluid :)
Les :yesnod:
Greg,
Old Nov 16, 2002 | 12:15 AM
thx2.net's Avatar
thx2.net
Default Re: Water on Windshield? (ZO6Les)
Dealer replaced check valve under warranty. Just told dealer that under hard acceleration drivers side washer squirts - tell them tech assist knows of new check valve.
Here's the code from my repair order if that helps.
N3860 .3.A.3 Diag and Replace Check Valve Per Tech Assist.
Old Nov 16, 2002 | 07:39 AM
hcvone's Avatar
hcvone
I installed Ford check valves, they are a pain to install in the cold, but they stop the washer fluid on the windshield.
To Water on Windshield?
