Gmpartsdirect.com vs. rock auto
Old Nov 24, 2019 | 02:36 PM
Chillo32's Avatar
Chillo32
Default Gmpartsdirect.com vs. rock auto
Does anyone know if there is a difference between the parts on gmpartsdirect.com and the oem ac delco parts sold on rock auto ie the parts listed on rock auto as oem direct replacement parts (not any other brands). Thanks.
Old Nov 25, 2019 | 12:41 AM
Chillo32's Avatar
Chillo32
Guess I should have said “aside from price”.......
Old Nov 25, 2019 | 12:43 PM
feeder82's Avatar
feeder82
I've bought from both and noticed no quality issues
amazon is another story
Old Nov 25, 2019 | 12:50 PM
Chillo32's Avatar
Chillo32
Thanks. Yeah. I tend to avoid amazon for major parts. Smaller things it ok.
it’s interesting, some parts from gm direct come either in a gm box (even though it’s still an ac delco part) or have a gm sticker on it. Rock auto obviously doesn’t have the gm tag on it. But the parts appear to be identical. I’m just wondering if there is any difference or the than price and other than the addition of the gm tag ie what if anything the gm tag gets you. Could be nothing. Could be better quality control, inspection etc.
Old Nov 25, 2019 | 03:50 PM
OregonDan's Avatar
OregonDan
Rock Auto is a stand alone auto parts business, with an inventory acquired from wholesalers, jobbers, manufacturers, and dealers. GMPartsDirect.com is a coalition of GM Dealers who sell their GM parts on-line, cooperatively, directly to retail customers.
Old Nov 25, 2019 | 04:07 PM
Chillo32's Avatar
Chillo32
thanks. Yeah. I get that. But I’m asking what is the substantive difference in the parts described above. Not the difference in the procedural businesses.
Old Nov 25, 2019 | 04:31 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Ac Delco isn’t GM. It’s a brand name.
Some Delco parts are what GM uses and you’ll see GM stickers on a Delco box with the same part number.
Other times the GM part number is different than Delco’s. That’s a part made by a different supplier, and Delco made its own version that isn’t actually GM, and you’ll see different part numbers.
GM partsdirect is official GM parts, whether they be Delco as the supplier or another.
Old Nov 25, 2019 | 04:37 PM
jackthelad's Avatar
jackthelad
In my experience there is no "substantive" difference. I've bought parts (especially trim parts) for my Chevy truck from RockAuto that were a perfect match for the GM part. Ditto with the C5. You will see alternative vendors (other than Delco) on RockAuto, but they will show an OEM part as well. For example, when I wanted a new oil pressure sensor, they listed 3 or 4 different manufacturers.
Old Nov 25, 2019 | 04:50 PM
Chillo32's Avatar
Chillo32
Here's an example of what I'm asking. This is an idler pulley purchased from gmpartsdirect. Obviously gm doesn't manufacture pulleys. They are ac delco pulleys. Also, obviously If you purchase this pulley from rockauto it won't come in a gm box. But it will be exactly the same part at least visually. Thus, my original question. What is the difference?
Old Nov 25, 2019 | 05:09 PM
DebRedZR1's Avatar
DebRedZR1
Moderator
CF Banner Relay Captain
West MI & JAX/NE Florida
Events Coordinator
St. Jude Donor '11-'17, '21
Let's Stick to the subject........................
Old Nov 25, 2019 | 05:12 PM
Chillo32's Avatar
Chillo32
Thanks, Deb. Just trying to get a substantive answer. :-)
Old Nov 25, 2019 | 05:52 PM
bigsapper's Avatar
bigsapper
If I understand your question (and I'm not sure I do, btw), when you order from GMPartsDirect, you will always get the correct OEM replacement part (of course, provided you select the right part for your application & it's still available).
RockAuto has equivalent replacement parts, but I would suspect anything other than the OEM replacement will be anywhere from junk to good enough.
bigsapper's Avatar
bigsapper
Honestly, the original question is a little ambiguous.
Old Nov 25, 2019 | 05:54 PM
Chillo32's Avatar
Chillo32
yeah. You didn’t read it closely enough or you have never purchased parts from both sites.
Old Nov 25, 2019 | 05:58 PM
Chillo32's Avatar
Chillo32
you also missed all the deleted comments about trump and politics. Hence the moderator’s comment.
Old Nov 25, 2019 | 06:32 PM
OregonDan's Avatar
OregonDan
Pardon me for having responded. Okay. Well, I'd guess that pretty much each part is different in quality since each manufacturer is different. Why would you think there is a difference? Do you have substantive evidence that parts from any one source are the same as any other source?
Old Nov 25, 2019 | 06:34 PM
OregonDan's Avatar
OregonDan
Whom do propose is the parent company to AC Delco?
To Gmpartsdirect.com vs. rock auto
Old Nov 25, 2019 | 06:38 PM
Chillo32's Avatar
Chillo32
Pardon my for having responded. Okay. Well, I'd guess that pretty much each part is different in quality since each manufacturer is different. Why would you think there is a difference? Do you have substantive evidence that parts from any one source are the same as any other source?
each manufacturer is different? Gm sells ac delco parts. Rock auto sells ac delco parts. They are the same manufacturer. Hence the question what is the difference?
Old Nov 25, 2019 | 06:47 PM
bigsapper's Avatar
bigsapper
Actually, I have.
Edited to emphasize what I was responding to.
Old Nov 25, 2019 | 06:48 PM
Chillo32's Avatar
Chillo32
A lot of responses here, but nothing that actually answers the question. That’s why I asked it!!!
