Tubing for Modified Ranger Method
Old 12-31-2019, 08:27 PM
Golfingbob
Golfingbob's Avatar
Default Tubing for Modified Ranger Method
Want to try the modified Ranger Method on my clutch fluid. Tried to find the 1/8” OD tubing and having trouble finding it. Found some 0.140 OD at a Hobby shop. Does anyone know the Max OD that can be used or any info on a syringe/ tubing combo that can be purchased as a single unit that will work??
thanks
Old 01-01-2020, 08:54 AM
tcfamy
tcfamy's Avatar
Bob,
Just ordered the syringe yesterday and should be here Friday?? from Amazon. Also ordered some Autometer 1/8" gauge line. I'll post results/picture soon.
Happy 2020 -- Tom
Old 01-01-2020, 09:03 AM
deriley
deriley's Avatar
Default tub
I got 3 feet at O'Reilly for .42 cents.
Old 01-01-2020, 09:05 AM
Golfingbob
Golfingbob's Avatar
Tom,
Happy New Year. Please keep me updated on the items you ordered and how they fit together.
thanks,
Bob
Old 01-01-2020, 09:08 AM
Golfingbob
Golfingbob's Avatar
Tub,
I looked online at O’Riley but couldn’t find the 1/8” OD??
Bob
Old 01-01-2020, 12:19 PM
deriley
deriley's Avatar
Default tub
I went to store and ask they had it'
Old 01-02-2020, 10:09 AM
STALION
STALION's Avatar
Location: ALL governments are legalized mobsters, so doesn't matter where I live :(
Any regular large syringe should work. Change the initial fluid, drive around for a bit, change again. Can be done of a few days.
USAZR1 (01-02-2020)
Old 01-02-2020, 10:27 AM
nschiff
nschiff's Avatar
Mc Master Carr is my go to when I cant get something locally. I would recommend Tygon tubing.
Old 01-02-2020, 07:49 PM
Rex99Coupe
Support Corvetteforum!
Rex99Coupe's Avatar
Tubing:
https://www.amazon.com/gp/product/B00ECFHYHQ/ref=ox_sc_act_title_1?smid=A17NMFB0WQDB5 F&psc=1
Syringe:
https://www.blowoutmedical.com/steri...n-syringe.html
Old 01-02-2020, 08:09 PM
heggsc5
heggsc5's Avatar
By modified, are you talking about getting tubing to suck even more fluid out of the line itself? Are you sure that won't risk introducing air into the line? I don't see why the normal Ranger method wouldn't accomplish the job without the risk...?
STALION (01-03-2020)
Old 01-03-2020, 07:09 AM
STALION
STALION's Avatar
Agreed!!! Bad idea to attempt to get it out of the line and risk air. Either use the normal method or change to a speed bleeder.
Old 01-03-2020, 08:56 AM
f6john
f6john's Avatar
This modified method doesn’t suck anything out of the line, rather it forces new fluid into the line, if I understand the process correctly.
Old 01-03-2020, 09:06 AM
Golfingbob
Golfingbob's Avatar
That is correct. Do a search for modified ranger method and it will have the details. New fluid is placed in the line.
Old 01-03-2020, 01:49 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
How bout some mild steel brake line type tubing, take the rubber stuff out of the equation. Bet the clutches work more precise may just do this myself.
When old brake lines go bad thebrake pedal sinks (lines swell)so....all this flushing I think is nonsense No car requires that all the time its something else.
Old 01-03-2020, 02:12 PM
flyingmfrc
flyingmfrc's Avatar
2020 C5 of the Year Winner- Unmodified
Just did the Clutch fluid. Found the 1/8th tubing at O'Reiley. Did it just like the mod ranger thread described. All it is , is replacing the dirty fluid. Mine wasn't so bad since the clutch was replaced when I bought the car a year and a half ago. I don't daily drive it, so not many miles. But it was a little dirty, and in some of the Youtube videos it was black. I'll just keep an eye on it once in a while. It was the easiest thing I've done to the car so far.
Old 01-03-2020, 06:16 PM
tcfamy
tcfamy's Avatar
Originally Posted by Golfingbob
Tom,
thanks,
Bob
Bob
Fitted the syringe to the autometer 1/8" OD tubing -- Works great with a 1" section of windshield washer hose as an adapter.
Tom
Old 01-03-2020, 07:18 PM
Golfingbob
Golfingbob's Avatar
Tom,
Looks great. Thanks for the info.
Bob
To Tubing for Modified Ranger Method
Quick Reply: Tubing for Modified Ranger Method
