Hood latches
Old Jan 6, 2020 | 09:36 AM
jjc508520's Avatar
jjc508520
Default Hood latches
Mine has done this since I got it - while standing on the drivers side I "slam the hood" and the latch nearest me does not catch (but the one on the pass side does). An easy fix?
Are we mostly "slammers" or "gentle pushers?"
Old Jan 6, 2020 | 09:38 AM
JR-01's Avatar
JR-01
Did you try lubrication?
Old Jan 6, 2020 | 10:05 AM
C5 4 ME's Avatar
C5 4 ME
Are we mostly "slammers" or "gentle pushers?"[/QUOTE]
Mine was doing the same thing. One side would latch and I would then walk around to the other side and gently push to latch. My mechanic noticed it and made some adjustments and now I can drop the hood from about 12" above closed and both sides latch. Hope this helps.
Old Jan 6, 2020 | 11:34 AM
rrwirsi's Avatar
rrwirsi
Mine does the same but only when I push the hood to close from the drivers side. Now I just close it from the passenger's side.
Old Jan 6, 2020 | 12:24 PM
STRMLNE's Avatar
STRMLNE
I like to gently push. (Don’t say that out loud)
Old Jan 6, 2020 | 03:54 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
You're doing it wrong. Doesn't matter which side you're on. Hold the hood IN THE CENTER and lower it till it's at the proper height, then let go and let it drop straight down DO NOT hold closer to one side or that side will be higher when you let go of the hood and it will start to twist and wobble as it falls, so one side will catch first and one side won't latch.
There's nothing wrong with the hood.
Old Jan 6, 2020 | 03:57 PM
STRMLNE's Avatar
STRMLNE
i def agree with this method to get both sides to slam at the same time. But I still don’t like slamming fiberglass. Nothing wrong with setting it down and clicking both sides softly.
Old Jan 6, 2020 | 04:09 PM
MadMax96's Avatar
MadMax96
This is what I do - I drop from about 12 inches while holding close to center, seems to work just fine.
Old Jan 6, 2020 | 06:59 PM
C5 4 ME's Avatar
C5 4 ME
Old Jan 6, 2020 | 10:35 PM
Mitch45's Avatar
Mitch45
adjust the stops that the hood sets on . mine was hard to close when I got it , turned the stops down a touch and works as it should . never have to slam it .
Old Jan 7, 2020 | 12:00 AM
CalF's Avatar
CalF
I just lower mine till it rests on the latch then push each side down gently to engage latch. Its not an old pickup truck.
Old Jan 7, 2020 | 01:05 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I always did mine like you do and still do it that way with my MCM hood...
Old Jan 7, 2020 | 01:10 AM
That’s how I closed the hood in my C5s.
To Hood latches
