[Z06] pfadt transmission mount
Old Jan 8, 2020 | 10:42 AM
Jacob Rose's Avatar
Jacob Rose
5th Gear
Default pfadt transmission mount
Hey guys I am new to the forum and was wondering if anyone has installed the pfadt transmission mount? I am having a bad vibration issue. Any help is appreciated!
Old Jan 8, 2020 | 11:53 AM
StingrayRebel's Avatar
StingrayRebel
check to make sure the pads on each end are making firm contact with the cradle, there should be shims that came with the mount that can be installed underneath the pads to sandwich them in between the mount and cradle
Old Jan 8, 2020 | 12:03 PM
Jacob Rose's Avatar
Jacob Rose
5th Gear
Okay, I will try that tonight. thanks
Old Jan 8, 2020 | 01:58 PM
zeevette's Avatar
zeevette
Also, make sure your dampener is removed from the diff. I used 1/8" thick pad made from a cut up silicone intake connector to fit between cradle and the main center mount. I've had zero vibration in mine.
Old Jan 8, 2020 | 02:05 PM
Jacob Rose's Avatar
Jacob Rose
5th Gear
Alright, I will also remove that. thanks for the input zeevette!
Old Jan 8, 2020 | 02:32 PM
jjc508520's Avatar
jjc508520
Didn't someone post here that if you used them on the trans that you need to have them on the engine as well?
Old Jan 9, 2020 | 08:11 AM
dskinsler83's Avatar
dskinsler83
Anyone have pics of what they are describing?
Old Jan 9, 2020 | 09:00 AM
feeder82's Avatar
feeder82
Old Jan 9, 2020 | 11:29 AM
dskinsler83
Haha sorry I meant the fixes.
Old Jan 9, 2020 | 02:56 PM
zeevette's Avatar
zeevette
No.
Old Jan 10, 2020 | 09:40 PM
Jacob Rose's Avatar
Jacob Rose
5th Gear
I tried all they stuff. I used the shims and took off that counterweight on the driver side of the diff. I still have a vibration. Could I have bent something while lifting the diff?
Old Jan 11, 2020 | 01:17 PM
killian96ss's Avatar
killian96ss
Do you also have urethane engine mounts?
Steve
Old Jan 11, 2020 | 01:43 PM
Jacob Rose's Avatar
Jacob Rose
5th Gear
No I do not
Old Jan 11, 2020 | 03:11 PM
killian96ss
Originally Posted by Jacob Rose
No I do not
That could be your problem then. I wouldn't personally have a urethane trans mount without urethane engine mounts. If the engine mounts are soft all driveline vibrations will transmit through the harder trans mount causing more vibrations in that area and more stress at the trans mounting point. IMO, It's much better to have urethane at all 3 mounting points to tie it all together.
Steve
To pfadt transmission mount
