Any difference in disconnecting battery
Old Jan 11, 2020 | 01:44 PM
royal flush's Avatar
royal flush
Default Any difference in disconnecting battery
or getting a tune--both have the same amount of drive time or miles to set monitors for smog check?
Old Jan 11, 2020 | 01:58 PM
STRMLNE's Avatar
STRMLNE
Say what now?
Old Jan 11, 2020 | 06:37 PM
Don’t have to worry about smog checks here, but if both things do require the same amount of time before you can get a good smog check, Not sure what your question really is.
Old Jan 11, 2020 | 07:54 PM
StingrayRebel's Avatar
StingrayRebel
a tune could be set up to make the readiness monitors show "ready" instantly after disconnecting and reconnecting the battery, if you have access to tuning software that might be easier than doing drive cycles if you are in a time crunch
Old Jan 11, 2020 | 09:40 PM
royal flush
My question was amount of time for either battery disc. or a tune--thx you answered it--about 100 miles should set moniters for ready?
Old Jan 12, 2020 | 02:36 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Originally Posted by STRMLNE
Say what now?
Old Jan 12, 2020 | 10:43 AM
Gordy M's Avatar
Gordy M
Some of the readiness monitors require 40 drive cycles to reset. Start drive so many miles an stop and set about 10 minutes. Years ago these were posted on one of the other Corvette sites.
Old Jan 12, 2020 | 11:08 AM
~Josh's Avatar
~Josh
Banned Scam/Spammer
You don’t need to disconnect the battery to reset, just use the dash buttons and clear any P-source codes.
To Any difference in disconnecting battery
