LED DRLs
Old Jan 25, 2020 | 10:14 AM
bigsapper's Avatar
bigsapper
Default LED DRLs
So who has done this conversion with switchbacks?
What did you use that actually works?
I'm having flickering issues with mine as well as both flashers blink when I turn on the turn signal.
Old Jan 25, 2020 | 10:52 AM
awches's Avatar
awches
Hyper harness for under the dash is what I used. when I switched.
Old Jan 25, 2020 | 11:04 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
You could wire a hidden incandescent bulb in series.
In several states then turn signal can still be white.
Old Jan 25, 2020 | 11:08 AM
FYRARMS's Avatar
FYRARMS
Bigsapper, who did you buy your switchback harness from? Also, have you already installed the anti-hyperflash harness?
Pretty sure the OP isn't looking to "band-aid" his problem. He would obviously like the LED switchbacks to function as they should.
Old Jan 25, 2020 | 11:30 AM
jcgunn's Avatar
jcgunn
Check out Forum Vendor RadioFlyer. he sells a kit with everything you need.
Old Jan 25, 2020 | 11:51 AM
peteinpa's Avatar
peteinpa
Agree got my bulbs,switchback harness and hyper flash from sharp light. Had similar issues before switching everything over. Be sure to use a little dielectric grease when you install the bulbs. Mine now work flawlessly.
Old Jan 25, 2020 | 11:55 AM
Stephen Meredith's Avatar
Stephen Meredith
Hyperflash harness & switchbacks both from ebay on mine as well as many other members. Going 2 years strong and by far the cheapest option
Old Jan 25, 2020 | 02:00 PM
bigsapper's Avatar
bigsapper
What bulbs are you using?
Old Jan 25, 2020 | 02:01 PM
bigsapper's Avatar
bigsapper
Correct. I have the RadioFlyer kit with the hyperflash harness. Not sure if it's an issue with the bulbs or harness.
Old Jan 25, 2020 | 02:03 PM
bigsapper's Avatar
bigsapper
What does this mean? Could you please be more specific?
Old Jan 31, 2020 | 07:42 AM
bigsapper's Avatar
bigsapper
Is there a harness everyone is using or resistors?
Old Jan 31, 2020 | 11:20 AM
awches's Avatar
awches
What I have in my records for all I changed out. I was repainting the nose at this time also.
Ebay Kerrymonk inc Hyper Fash Fix Bypass $56.54
EBay axi auto LED Turn Sig Bulbs 4 of them. $39.88
Oemassive Signal parking Lights assy $47.95
Signal parking light sockets pigtails $28.48
Old Feb 3, 2020 | 01:38 AM
ErikwithAK01's Avatar
ErikwithAK01
2nd for Radioflyer stuff! I have all my lights done by George
Old Feb 3, 2020 | 10:12 AM
killian96ss's Avatar
killian96ss
I have the Corvette Envy hyperflash harness and led bulbs in my 02Z.
https://www.corvetteenvy.com/collect...-flash-harness
Steve
Old Mar 13, 2020 | 10:26 AM
bigsapper's Avatar
bigsapper
Well, I finally fixed this issue. It was pretty simple really. Anyone want to guess how?
Old Mar 13, 2020 | 10:42 AM
chasboy's Avatar
chasboy
Oldtimer
you checked your ground connections?
I tried switchbacks and I find that many eBay bulbs, despite the price are inconsistent. Mine started flickering so I went back to Sylvania amber Zevos and they are bulletproof
Old Mar 13, 2020 | 10:52 AM
joezr2's Avatar
joezr2
I'm guessing ground too...
I went with the radioflyer switchbacks, clear lenses including the led strips and hyperflash harness. It was a fun project and they look great really updating the look of the car in a subtle way. Also, with the switchback bulbs and harness included, they don't function like some of the cheaper versions.
some cheaper ones flash: white/amber/white/amber
The radioflyer kit is solid white for DRL.
flashing is: white goes off
amber/off/amber/off/amber/off
white goes back on
To LED DRLs
Old Mar 13, 2020 | 11:00 AM
bigsapper's Avatar
bigsapper
Nope, grounds were good as well as battery & alternator checked out GTG.
Old Mar 13, 2020 | 11:15 AM
chasboy's Avatar
chasboy
Oldtimer
I’ll take polarity for $200 Alex....
Old Mar 13, 2020 | 11:20 AM
bigsapper's Avatar
bigsapper
Nope. But it is a trick question.
I put factory bulbs back in.
