Auto shift cable
Old Feb 1, 2020 | 01:41 PM
regalvette's Avatar
regalvette
Default Auto shift cable
Like to know those of you who had a shift cable problem can remember what the mileage on the car was when the bushing let go, Also can you remember if it was exceptionally cold or hot out at the time of failure.
Old Feb 1, 2020 | 03:00 PM
awches's Avatar
awches
Mine failed last Monday but in the garage when I wanted to back out and it didn't want to. 20 miles lacking 148K miles on my 03 Coupe and around 50F
Old Feb 1, 2020 | 04:18 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
42K miles ...60 degrees F...mileage doesn't matter...it is time....just my .02...
Old Feb 7, 2020 | 04:17 PM
unlvrebel's Avatar
unlvrebel
Age is the driver. 2016 for my 2004. Plastic just gets brittle over time. After a certain point that plastic is living on borrowed time. I had around 100,000 miles at the time.
Old Feb 8, 2020 | 03:57 AM
golfnutts's Avatar
golfnutts
The last oil change (57,000 miles), I had the dealership change the grommet on the transmission since it was up on the rack. The cost was $59.00. Just did it for preventive maintenance, since I plan on another cross country trip this spring.
Old Feb 8, 2020 | 10:41 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
Good idea...but the shifter cable end bushing will be in the same condition so it would be a good idea it replaced also so you do not get stuck somewhere...
Old Feb 8, 2020 | 02:12 PM
awches's Avatar
awches
When I went to just change the rear bushing, I found the holder warped and would not hold the bushing very good. So, off to the shop it went for a cable change. Owner of the Corvette shop says he never changes just the bushings. Now, I have to agree with him. Cours I had just rolled 147,975 miles when mine broke and no record of any thing being done to it.
Old Feb 8, 2020 | 02:18 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I tried to tell you this a while back in another thread but you are just a stubborn old goat like myself...
Old Feb 8, 2020 | 03:16 PM
Daddy o's Avatar
Daddy o
Mine didn't brake, but it started to feel different when I moved the shifter from one gear to another. I decided to not chance it so I replaced the whole cable on my 04 Spec. edition with 26,000 miles. New cable cost $65 from rock auto. If you have a way to raise your car like a quick Jack, it's a simple job. The hardest part is the screws on the heat shield. About 34 of them and they seem to never end! Be sure to route it like the old one or you will melt it the first time you use it. There are you tube vids that show short cuts, but don't do it! You'll brake the new one one way or another. DO IT RIGHT and all will be fine. About an hour or so and $65 and you are good like new. I could never understand why someone would pay $20 or so just for the bushings instead of doing a complete cable for $65. Penny wise and dollar foolish IMO. If you drive a vette and the $45 difference is a big deal, then you own the wrong car. Plastic gets old over time and will fail sooner or later. Good luck!
Old Feb 9, 2020 | 05:30 AM
golfnutts's Avatar
golfnutts
At that time in life, NOT crawling underneath cars and turning wrenches, rather watch someone else do it while I drink my coffee. If I did it, it would take me 30 minutes just trying to get up on my feet. It took me 3 days to change brakes and rotors.
Old Feb 9, 2020 | 07:02 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
So did you learn your lesson...old goat?
Old Feb 9, 2020 | 09:08 AM
awches's Avatar
awches
LOL That's why mine went to the shop to change the cable out. I could do the bushing on the quickjacks but my damage back will not stand the taking the exhaust and cover off. . Maybe, just maybe, if I would of bought a 2 post lift instead of the quickjacks I would of went for it. Glad I was able to change out the shocks and all the wheel bearings and other stuff I've done on the car before the last injury.
Old Feb 9, 2020 | 11:04 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...and here, i thought you were just another stubborn old goat...
So how much did it cost you to replace the cable? $$$$$$$$$$$$$$$$$$$$
Old Feb 9, 2020 | 11:33 AM
golfnutts's Avatar
golfnutts
My mind says sure you can do it, my body says "DUMB ***" go ahead..... Oh wait that is what my wife is saying in the background....
Old Feb 9, 2020 | 01:08 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
wifey sounds like she knows you well..."DUMB ***"...
Old Feb 9, 2020 | 06:36 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
S Florida 80 degrees plus, when the cable broke!
Old Feb 10, 2020 | 01:49 AM
awches's Avatar
awches
He's busy so it's gonna be sometimes this week. Quote was around 250 bucks. Truck is lovin' the attention it gets when the vette is away.
To Auto shift cable
Old Feb 10, 2020 | 04:24 AM
Daddy o's Avatar
Daddy o
$250! Geez, if we were closer I'd do it for you for $150 all day long and have a fresh pot of coffee for you so you could watch. I know a shop has to make a profit, but $250 for a cable is on the high side. That's dealer pricing!
Old Feb 10, 2020 | 04:39 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
ok...i understand now...i thought you already took it to the shop cause yesterday you said..."That's why mine went to the shop to change the cable out."
...my guy charged less than half of that for the labor...so i'm guessing that was with the cable included( i brought my own $67 cable)...it took him less than 1 hour to do the job...i guess he is pretty fast plus he has a big lift and power tools and the experience...after adjusting the lift arms underneath (he got the car in the air in 5 mins)...he dropped the 2 pipes in 5 mins and took the tunnel plate off in another 5 mins(there were a lot of bolts lol) then unhooked the cable in 10 mins then put the new cable on in 5 mins then tunnel plate back on in 15 mins(he torqued the bolts) then the pipes back on in 5 mins....talked with me 5 mins...moving fast he actually did it in 55 minutes...so he was one fast little bugger...lol
it was amazing to watch...he is the "Corvette specialist"
I would have still been putting the car up on jacks......then who even knows how long it would have taken...
Hope it goes well for you
Old Feb 10, 2020 | 04:41 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
I think that included the price of the cable......next time mine breaks i'll drive up to NY and let you do mine...
