Replacement lights
Old Feb 8, 2020 | 11:25 PM
terrymccoyc6's Avatar
terrymccoyc6
Default Replacement lights
My head is spinning. I've been trying to figure out. What is the best? Switchback light bulb replacement for my turn signals I have already bought the harness stop the hyper Flash. But this time I'm just looking to do the turn signals because one of my light sockets burned up any suggestions what type and best place to buy them?
Old Feb 9, 2020 | 07:37 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I replaced mine with a replacement set of corner light housings and the switchback bulbs from forum vendor SharpLight Innovations: https://sharplightinnovations.com/ (used to be RadioFlyer Innovations).
Old Feb 9, 2020 | 09:01 AM
awches's Avatar
awches
Don't get the cheap pig taills to replace the sockets. I did and a year later they were toast but with stock lights. I replace everything last year going LED on the lights this time.
Old Feb 9, 2020 | 11:44 AM
Dave in Pa's Avatar
Dave in Pa
Do this ^^^^^^^^^^^^^^!! Great Vendor!
Old Feb 9, 2020 | 07:19 PM
terrymccoyc6
Default Led
How would you say these compared to the one sold by Corvette mods?
Old Feb 9, 2020 | 07:48 PM
StingrayRebel's Avatar
StingrayRebel
the stock bulbs are the issue not the pigtails, if you had used leds when you replaced the pigtails chances are the replacements wouldn't have failed
Old Feb 18, 2020 | 12:24 PM
C5VetteKing's Avatar
C5VetteKing
Veteran: Marine Corps
I replace all my exterior and interior lights with the LEDs and so far it has been working good. The front corners are the switchbacks with the clear housing and it very distinctive and clear, too. My rear halo LEDs, third brake light LEDs, rear side marker lens replace with red crystal cut lens with a red LED bulb will make it very noticeable, especially at night.
Old Feb 18, 2020 | 07:28 PM
JoeP01c5's Avatar
JoeP01c5
These are the ones I just bought they seem fine. Way better than stock.
New housings
Driving position
Turn signal
Switch backs
Pack of corner lights
Old Feb 19, 2020 | 11:04 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Our Cree XB-D switchback bulbs are the brightest that will fit in the C5 housing (Most of the other bulbs will not fit due to the bottom-mount and small reflector).
We also have a white DRL harness that will keep your daytime running lights white and still allow for amber turn signals. (plus you can add the Cree switchback bulbs for a discount)
https://sharplightinnovations.com/sh...orvette&page=2
Old Feb 19, 2020 | 12:49 PM
awches's Avatar
awches
It is an issue when the stock ones lasted 18 years with stock lighting and the replacement last a year with stock lighting.
To Replacement lights
