[Z06] C5 Memory
Old Nov 19, 2002 | 10:26 PM
Westsideguy's Avatar
Westsideguy
Default C5 Memory
The memory on my car seems to work / not work intermittently.
Open the door - get in - fasten seat belt - put in the key - close the door- put key in the ignition- push in clutch - turn key. Now the memory (seat) either works or not. I've tried turning over the key and altering the above order. But can't seem to get the pattern. Any ideas??
Bruce
2003 Z06 Blk/ Blk
Old Nov 19, 2002 | 10:50 PM
Gaijin's Avatar
Gaijin
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: C5 Memory (Westsideguy)
When you exit and close the door after driving, do you hit the power lock button on the key fob to lock and engage the alarm. You have to do that everytime you shut off the engine, exit the car. If not, it will not work when you get in and turn the key to "ignition."
Old Nov 21, 2002 | 01:46 PM
CRE_Vette's Avatar
CRE_Vette
My car is the same
Old Nov 21, 2002 | 02:08 PM
Westsideguy
The (Matia) Dealer just got back to me. They want to replace the seat module about $700. Let you know if it works
Old Nov 21, 2002 | 03:57 PM
TRR's Avatar
TRR
You need to push the Unlock botton on the key fobe first.
TRR
To C5 Memory
