Recently learned that if you hold the gas pedal to the floor and push the start button in a C6, it will crank but not start.
Many think that it's good to crank the engine for a few seconds before starting after winter storage.
Just wondering if that works on C5s.
Yes if your hold the pedal to the floor the car will enter the "clear flood mode" and not fire the injectors. The car will not start but circulate oil when cranking. It might take a while to get oil pressure after sitting for some time.
back in the 18 hundreds I had a chevy 283 with a bad cam lobe, decided to put a brick on the gas pedal and see how long it would last, after filling the entire neighborhood with smoke (about a half hour) I decided it was not going to blow. took the engine out and set it behind the garage,(Michigan weather) after about two years a friend needed a 283 crank, we took the engine apart and all the rod and main bearings were still full of oil ???? so just start it already !!!!!!!!!!!!!!!
Ahhh the 18 hundreds great times 283's and 2 speed power glides !!!
Since mine rattles pretty good for a couple seconds when I first fire it up after 6 months, cranking it for a few seconds without starting sounds like a good idea. Won't hurt anything.
mine sat from 1 oct to 16 march (the longest it has been inactive) and with a battery tender it did not wait a millisecond, it just started running. felt good driving it. woweee
Hmmm... what is the rational for cranking it for a few seconds, without starting, vs just cranking it to start? Wouldn't you be cranking 'dry' either way?
If the engine turns without combustion there is less stress on the connecting rods and crank. This was and still is advised for two stroke engines after prolonged storage. Two stroke engines rely on the gas/oil mixture to lubricate the crank /bearings. If the crank bearing/ connecting rod area on a four stroke engine does not retain oil you have serious problems. Unless you think you have a rod knock I wouldn’t bother.
The valve train also has much more stress while running. It sure would not hurt to crank for a few seconds without starting to get oil to lifters, rockers and cam after winter hibernation.
You’d be cranking only, which is a much lower RPM than if you just started cold. At least that’s my thinking
