Stupid Question
Old Mar 13, 2020 | 06:32 PM
orca13's Avatar
orca13
Default Stupid Question
Wondering if anyone knows a trick to get out of a 04 convertible. Had 14 screws put in my back. having a little trouble getting up. afraid to get in vette and not be able to get out. lol
Popular Reply
Mar 13, 2020, 06:57 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
This might help you out I think. It's called a car door cane. Good luck with your recovery and you get back to as normal as you can.
Old Mar 13, 2020 | 06:39 PM
JimHarris4's Avatar
JimHarris4
Default Prayers
Good luck, bro. Prayers for you.
I put my left hand on the door sill and push up and out.
Old Mar 13, 2020 | 06:57 PM
mstromquist
Old Mar 13, 2020 | 07:00 PM
Fcar 98's Avatar
Fcar 98
Getting in, *** first and sit. Turn legs in. Getting out, legs turn out, stand up, *** will follow.
Old Mar 13, 2020 | 07:43 PM
Hitman227's Avatar
Hitman227
Yes,
Left hand on the sill, right on the wheel, if car is off, if not, right on the sill as well...good luck
Old Mar 13, 2020 | 07:52 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
Sounds like you could use a helping hand. Prayers for your healing brother.
Old Mar 13, 2020 | 08:08 PM
JR-01's Avatar
JR-01
On the door jamb just below the latch there is a little shelf. Place your hand there and hoist yourself up.
Old Mar 14, 2020 | 12:19 AM
ochsnal's Avatar
ochsnal
7th Gear
Default Been there.
Broke my back in a motorcycle accident back in 2015. Vertebrates T2 through T10. Fortunate I can still walk. Long story short, seat in and down, legs in. Reverse on exiting. Time practice and determination. Many good suggestions here. All the best to you!
Old Mar 14, 2020 | 08:15 AM
rrwirsi's Avatar
rrwirsi
I have a very difficult left knee and this device makes it easier entering and exiting my '04 vert.
Old Mar 14, 2020 | 09:17 AM
bjones7131's Avatar
bjones7131
On the door jamb just below the latch there is a little shelf, left hard there and hook your right arm elbow over the top of the car and hoist yourself up. B well brother
Old Mar 14, 2020 | 09:52 AM
Clancy209's Avatar
Clancy209
Put feet in while I lean against the back then slide down. Make sure nothing in your back pockets
Old Mar 14, 2020 | 01:48 PM
friou's Avatar
friou
I have suffered back injuries in the past and it does make entry/exit a bit of a challenge. I have used most of the methods described by posters above. Finally settled on the following. Entry: Place right hand on the side of the seat back at the hump, right leg in, lower into the seat at an angle facing out, half your butt on the seat and then slide across the seat all the way in then left leg in. Exit: Swivel in seat, left leg out, left hand on hump by door latch, swivel to your left, right leg out, use left hand/arm to help power yourself out of the car and into standing. Works for me but one of the above methods or some variation should be of some help. Hope you can work it out. Best wishes to you!
Old Mar 14, 2020 | 01:53 PM
Edmund Iverson's Avatar
Edmund Iverson
I know the Vette in the video is a C6, but here is a quick vid about entry and exit; hope this helps!-
Here's another pertaining to a C5--
Old Mar 14, 2020 | 02:20 PM
bc6152's Avatar
bc6152
This is the best suggestion IMO and how I do it...
Old Mar 14, 2020 | 02:42 PM
CQRT's Avatar
CQRT
Getting in, *** first and sit. Turn legs in. Getting out, legs turn out, (see note) stand up, *** will follow.
I have 8 screws and rods in my lower back - -getting in is the easy part- right . . .? I use the same method as above, but getting out flare my elbows against the A and B pillars to help raise out of the car or in a roadster, push left hand off the seat back.
Old Mar 14, 2020 | 04:45 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
My wife has had her spine and neck fused. While she can no longer drive a standard transmission car this device has been a big help for her.
Old Mar 14, 2020 | 05:07 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
A lot of good suggestions above, but,hate to hear about your back issues. Prayers for a full recovery and hope you find the perfect way to enter/exit your car. You definitely deserve some "Corvette Therapy"!!
By the way....this is definitely not a stupid question. Your question and the answers provided will probably benefit many of our forum brothers and sisters either now or in later years!
To Stupid Question
Old Mar 15, 2020 | 02:06 AM
Interesting device. Don't think I have seen that one before.
Doing it this way should help with your back.
Old Mar 15, 2020 | 08:27 PM
bobgroger's Avatar
bobgroger
Don't grab the seat to get out, that is the cause of all the broken seams you see. My car is lowered pretty drastically. I just figure when I can't get out anymore the for sale sign goes on.
Old Mar 15, 2020 | 09:50 PM
orca13's Avatar
orca13
Except I have a convertible,
