What Tech 2 to buy?
Old Sep 6, 2023 | 10:29 AM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
Originally Posted by Kubs
Brining this thread back as I am looking to potentially buy a Tech II.
Does this ebay dongle allow programming too, or just code reading? It just says scanner.
I have this exact unit and yes, it can read and write. I used mine to turn on the TPMS system on my Z06, super simple. Can it do everything a GM Tech2 can do...I don't know since I don't have a GM Tech2 however I have not found one thing it can't do that a GM Tech2 is supposed to do. The software is finnicky to get installed and the instructions aren't great but once you have it installed, it works just fine.
I saw on another thread that you are looking to replace a BCM. It is my understanding that this unit can make all the changes necessary to reconfigure a new (to you) BCM. You would basically go to the BCM RPO Reprogram section and turn on/off the RPO codes that match your car. (see below)
Old Sep 6, 2023 | 01:42 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Awesome! Thanks!
Old Sep 6, 2023 | 04:38 PM
indebt's Avatar
indebt
Veteran: Marine Corps
Check out this thread towards the end. I just bought a TopDon scanner and it's awesome. Bi-directional, activate sensors, see and record live data. Usually like $70 or so but got mine for free with my Amazon points. Reads all the modules. Highly recommend. Also has some alternative scanners listed.
http://www.corvetteforum.com/forums/...c5-and-c7.html
Old Sep 6, 2023 | 07:41 PM
LannyL81's Avatar
LannyL81
Have questions for you guys:
1. The Tech2win program.....is it correct that this is for diagnostics only; not bi-directional?
2. What TOPDON unit did you get? I did a search and found way too many choices.
Thanks,
Old Sep 6, 2023 | 09:57 PM
indebt's Avatar
indebt
Thanks,
Here you go. It's a TopDon Topscan Bluetooth scanner
Old Sep 6, 2023 | 10:21 PM
Smoken1's Avatar
Smoken1
I need to look into one of these for the Honda cars in the family
Old Sep 7, 2023 | 06:58 PM
jcj63's Avatar
jcj63
Are you using the TopDon on a C5? I looked at their website and it shows 2005 and up.
Old Sep 7, 2023 | 08:35 PM
LannyL81's Avatar
LannyL81
Thanks....I will go looking for it.
Old Sep 8, 2023 | 09:22 AM
AsphaltGator's Avatar
AsphaltGator
I use the VCXNano with tech2win on my 99 Coup.
William
Old Sep 9, 2023 | 12:26 PM
captras's Avatar
captras
May need to replace my mag ride control shocks soon. Planning on going the Bilstein route but then need to reprogram to eliminate them from the system. I think I read a shop charges 200 to do it. Does this allow you to do that reprogramming?
Old Sep 9, 2023 | 08:07 PM
ericba's Avatar
ericba
Thanks,
It is bi-directional...read & write.
Old Sep 9, 2023 | 08:12 PM
ericba's Avatar
ericba
If you use the VCXNano & Tech2win, you can turn off the RPO F45 (Real Time Damping).
Old Sep 9, 2023 | 09:59 PM
  #33
indebt's Avatar
indebt
Yes, just used it and it read my 2001. Trying to see if I can turn the TPMS on my 2001 Z06 with it. I believe I can.
Old Dec 12, 2023 | 02:17 AM
  #34
douglasjre's Avatar
douglasjre
VCXNano and Tech2win Just looks like a bunch of Chinese spyware. Anywhere I can get a clean copy without the spyware by PRC?
Review on Amazon: Quirky and software is full of malware
Amazon Amazon
Old Dec 12, 2023 | 02:22 AM
  #35
douglasjre's Avatar
douglasjre
Can I get VCXNano and use it with the windows OBD2 software of my choice? After all I do have my own software.....
I have generic mode on my Toyota dealer software. It lets me graph each cylinder's ignition firing. That's what I need to do right now....
Old Dec 12, 2023 | 02:37 AM
  #36
douglasjre's Avatar
douglasjre
For instance, this one supports the Corvettes protocol can iso 15765-4 https://a.co/d/hxmmhxe shouldn't this work as well?
