Mismatched outer tie rod ends
Old Apr 5, 2020 | 11:59 AM
jrp1588's Avatar
jrp1588
Default Mismatched outer tie rod ends
I'm almost positive this doesn't matter as long as they're properly aligned, but it's making my a** itch. A couple weeks ago, I replaced the passenger rear outer tie rod end with the OE AC Delco piece. Soon after, I discovered the driver's side boot was torn, and at that point had discovered Eckler's sold a heavy duty greasable one for cheaper than OE, so I got that one. Would it be worth it to order another Eckler's one for the passenger side so they match and try to sell the AC Delco one since it has MAYBE 15 miles on it, or am I overthinking it because I've been stuck in the house for a month?
Old Apr 5, 2020 | 12:58 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
That is the kind of stuff that bothers the hell out of me even though it will have no detrimental effects in the performance of the car.
Truth be told, your car is fine.
If you haven't gotten it aligned yet and it bugs you enough, go ahead and buy the one you want and then get it aligned.
Old Apr 5, 2020 | 01:50 PM
jrp1588's Avatar
jrp1588
Yeah, not aligned yet, but as you said, probably not worth worrying about. Not like I race the thing, but the asymmetry bothers me, especially when the one claims to be an upgrade.
Old Apr 5, 2020 | 02:47 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Same here!
Old Apr 6, 2020 | 08:43 AM
RichyB33's Avatar
RichyB33
Even if you do race it, after the alignment the car will be mechanically fine. The problem lies with the owner. I have the same issue. My OCD goes crazy when things don't match which usually costs me money that I don't want to spend because I end up replacing a set rather than just the bad part.
Old Apr 6, 2020 | 08:53 AM
jrp1588's Avatar
jrp1588
yeah, frankly I didn't even notice driving around with one bad end on the rear AND the front until I had the car in the air for its last oil change, and gave the tires the wiggle check. I'll just let it go.
Old Apr 6, 2020 | 12:05 PM
knewblewkorvette's Avatar
knewblewkorvette
Funny, I'm going through the same dilemma. Saw that the boots were torn on my red 99 on the driver's side front and rear. So I ordered a grease-able one for the front and stock for the rear. Yesterday, I go to put on the passenger's sides brakes and then notice the front boot is also torn. How in the hell did I miss that the first time? Now I have to order another front tie rod end
Old Apr 6, 2020 | 12:08 PM
jrp1588's Avatar
jrp1588
I did the same. The front passenger and driver were hosed, so I ordered replacements. When I went to install coil overs, I noticed the drivers side boots were torn, but no play. Had to do it all twice. Haha
To Mismatched outer tie rod ends
