I'm would like to know people's reviews who have purchased this or something like it. How did it work for you? Worth the cost in your opinion?
https://www.zip-corvette.com/98-04-quiet-ride-compartment-divider-w-z06-emblem.html?gclid=CjwKCAjwp-X0BRAFEiwAheRui0V3Je6cYZbD0_jJauraat9jCm Xd1YYcQXPOQ5OU81lx8HI4o3vdehoCVkcQAvD_Bw E
Are you referring to the partition that is put in the trunk area?
If yes, then my answer is for me is it did help reduce road noise along with other stuff like replace the run flat tires and put a rubber floor mat in the trunk area in my vert. All contributed to reducing the road noise without doing major insulation add on's that other have used for various areas of the car.
Yes as that is what the name of the product is and what the link is to. Thanks for your opinion of the product. I want to be sure it works before dropping the cash on it. Was there anything specific you used for trunk liner or just any rubber mat?
I've got one. It's ok. I mainly wanted to block the view of the trunk from the front area. I've got B&B Quad Exhaust installed and it did quiet down the burbling of the exhaust on deceleration which isn't what I wanted, but obviously understood that's what it would do. I would say the volume change wasn't huge, but definitely noticeable.
