LS Cam packages include:
LMT Custom Camshaft
LMT Hardened Pushrods
Brian Tooley Racing Spring Kit (cams up to .660 lift)
GM Crank Seal, Water Pump Gaskets, Front Cover
Melling High Volume Oil Pump
LS2 Timing chain
GM Crank Bolt
NGK Spark plugs
Oil Change and Filter
Professional Installation
Dyno Tune with Before and After Graphs
A performance shop in my area is currently running this cam package deal. Looking for others opinion on this. I would also be buying BTR trunnion upgrade. Is this actually a “deal”? Anything else I should look to
upgrade while I’m in there? Currently have a Varram, Kooks long tubes that will be installed at the same time and a Corsa extreme already on. I know it’s hard to say but any ideas what kind of gains I would see from this? Thanks in advance.
I've seen less expensive packages, but it's not a ripoff. If you still have the stock clutch, it'll be next. I would suggest the BTR2 (I think) that's 227-234@113 for an easy going cam that'll give you a nice bump.
Yeah splurge for the ATI underdrive dampener, otherwise looks great.
Lots of options on custom cam specs, talk to the Tuner about your goals, can compare it to BTR Stage I, II, III
I’m starting to think this might be the best choice.
I would still think about the headers, valve springs, pushrods, trunnions and a balancer with a SC install. And with all of that and since you're right there...a baby blower cam. You'll still need that clutch... The madness
Yeah I say go do the cam and valvetrain 1st, but use a blower cam. Then later on when you can afford, actually do the blower. This will keep required boost down at the minimal level for your power goals.
yours sounds pretty good to me
i just got my quote
i know it's probably not that bad but...
scared the crap out of me
BTR STAGE 3 LS1/LS6 N/A CAMSHAFT
PAC POLISHED .660 DAUL VALVE SPRINGS
7.4 PUSHRODS
GM CAM 4X SPROCKET 3 BOLT
ARP-LS1 CHEVY CAM BOLT KIT
GM TIMING CHAIN LS/LT
MELLINGS LS HIGH VOLUMN OIL PUMP
GM LS7 LIFTER SET
GM LIFTER TRAY
PRC STAGE 2.5 LS1 CNC PORTED CYLINDER HEADS
GM LS1 MLS 3.920 BORE HEAD GASKET 5.7 ARP 04+ LS6 HEAD BOLT KIT
COMP CAMS LSX ROCKER TRUNION KIT
GM LS TIMING COVER GASKET
GM LS FRONT SEAL
GM LS EXHAUST MANIFOLD GASKET
GM LS WATER PUMP GASKET
GM OIL PAN GASKET LS ENGINES
GM CRANK BOLT LS1
ATI SUPER DAMPENER 10% UNDERDRIVE HARMONIC DAMPENER- LS1
GATES ACCESSORY DRIVE BELT- 10% UNDERDRIVE LS1
GATES A/C BELT
KOOKS 1 7/8" HEADERS W/ EMISSION FITTINGS-
YANK SS 3200 CONVERTER 4L60E
MSD LS1 WIRE SET VETTE-CAMARO (RED)
NGK TR55 V-POWER SPARK PLUG
ROYAL PURPLE 5W30 SYNTHETIC OIL
DEXCOOL COOLANT
LABOR
Disassemble the Engine, Clean/Inspect Parts, Re-assemble the Engine
Install Yank Torque Convertor
Install Oil pump
Install Trunion Kit
Install Kook's Longtube Headers
Dyno Tune/ ECM Recalibration
Parts 6039.80
Labor 2735.00
SubTotal 8856.85
Salestax 597.84 TOTAL9454.69
That's a lot, but it's also a lot of parts and work to be done. I didn't go through and try to estimate it though, lol. It's def going to be beast, esp with that Stage III cam with all the other supporting parts, will like to rev high and strong..
