Water pump is leaking
Old May 18, 2020 | 10:55 PM
kingfurook's Avatar
kingfurook
Default Water pump is leaking
Just finished fixing the harmonic balancer, now the water pump is leaking. In retrospect I'm happy the puddle under the car wasn't oil. Was scared the HB main seal was leaking.
What pump / thermostat / housing have you purchased? Summit has the ACdelco, I assume it makes sense to replace the thermostat and it's housing too.
Old May 18, 2020 | 11:08 PM
Billyjean9999's Avatar
Billyjean9999
Did you use new gaskets when you re-installed the water pump after hb?
Old May 18, 2020 | 11:09 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
just buy OEM and its not any real work to do the stat too
Old May 19, 2020 | 09:16 AM
SenorZ06_Tacos's Avatar
SenorZ06_Tacos
I would go with the LS7/LS3 water pump, they say its lighter, gets you a couple hp. FYI i think it requires the thermostat to be changed as well.
Old May 19, 2020 | 09:32 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Whatever lifetime warranty parts store part is available. That way, if/when it fails down the line, you can replace it and aren't stuck waiting for Summit to ship you one.
Old May 19, 2020 | 09:43 AM
TOPCATHR's Avatar
TOPCATHR
I did my balancer removing the water pump not required.....
Old May 19, 2020 | 12:24 PM
kingfurook's Avatar
kingfurook
Agreed. I didn't touch the water pump during the install. It is just coincidence that this issue has risen, but it was bound to sooner or later.
Old May 19, 2020 | 12:52 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Since you changed the balancer yourself, you can definitely handle the water pump. I just did mine. I replaced everything with stock AC Delco parts. It can get a bit messy and it's a pain to get to. I used a tiny bit of silicone to hold the gaskets in place when putting the new pump on. You'll know why when you get to that point. Good luck.
Old May 19, 2020 | 01:13 PM
Stingroo's Avatar
Stingroo
Indian head gasket shellac is great for that. Used it on engines I've built for YEARS.
Old May 19, 2020 | 03:57 PM
Deke Keyes's Avatar
Deke Keyes
Same here. Ironically just replaced mine this past weekend. And the advice to use some RTV to hold the gaskets in place is nearly mandatory. Its also going to make a mess no matter how big your catch pan is! Took about 3 hours.
Old May 19, 2020 | 05:01 PM
Billyjean9999
it should come off so you can do front seal and front cover seal.
Old May 19, 2020 | 05:47 PM
AC Delco parts are a good choice. That is what I would go with.
To Water pump is leaking
