[Z06] Rear window tint
Old Jun 2, 2020 | 09:56 AM
jjc508520's Avatar
jjc508520
Default Rear window tint
I had my side and rear windows tinted yesterday and was disappointed to see the results on the rear - the "dots" at the top of the rear glass prevent the tint from making good adhesion. We agreed that we would let it cure for 2 weeks and that time (1) cut away the top strip and perhaps (2) replace that section with black vinyl.
Has anyone else wrestled with this?
Old Jun 2, 2020 | 10:02 AM
RXTbone's Avatar
RXTbone
I ran into the same issue - and unfortunately was unable to find a way around. My tint was film. I suspect you would not have the issue with a spray tint - which is what I'll try the next time around.
Old Jun 2, 2020 | 10:24 AM
ericba's Avatar
ericba
St. Jude Donor '21-'22-'23
You need to see if your tinter can get their hands on Dotrix which is designed to minimize this issue. When I had my Vette tinted, I was very unsatisfied with the rear window. After doing some research on this issue, the best results appear to come from using the Dotrix product. I suggested this to my tinter and he bought some and re-tinted my rear window (no charge even though I offered). Is it perfect? No, but it is MUCH better.I have read about (and watched videos about) everything from sanding the dots down (to allow for better adhesion) to using spray tints and some suggest to paint the top portion of the rear window flat black (inside) and not deal with the dots. .Some tinters online suggest it boils down to the experience of the tinter (they claim they can use standard tint and have it lay perfectly...I don't know). I will be curious if anyone has found a perfect (or near perfect) solution. Like I said, mine is VERY good but unfortunately I am pretty **** so if someone shows perfect results...I may be tempted... Good Luck
Eric
Old Jun 2, 2020 | 11:42 AM
DEFCON5's Avatar
DEFCON5
Glad I read this. I have an appointment to get my windows retinted next Wednesday. I will bring this up prior to the application.
Old Jun 2, 2020 | 11:53 AM
BamaFRC99's Avatar
BamaFRC99
When I had the windows tinted on my FRC I ran into the same issue on the rear glass. I tried my best to press the tint into the dots and it got a bit better but ultimately I wasn't happy with it and went back to the shop to have it re-done.
The shop recommended cutting the tint right where the dots begin and placing a black gloss vinyl over that portion. I thought it would look out of place but once it was completed it looked good. You can't really tell that it is vinyl unless you "know its there" or look from a low angle - you don't see it from inside the car.
Old Jun 2, 2020 | 01:13 PM
Patches's Avatar
Patches
When I had my C7 done several years ago, one of the primary considerations on choosing the right shop is how they deal with the upper portion of the rear hatch window. The emblem dots, which are actually shaped like tiny C7 emblems, can be tricky if they are not handled properly. The film can delaminate around the raised emblems, causing whitish spots to appear around the emblems, if the tint is not applied using the correct technique.
Some tint shops will paint that section black while others will glue a strip of opaque black plastic to it to avoid dealing with tint film over the area. Other shops will attempt to sand the emblems to reduce their profile so the tint film might stick to it better but my tint guy said that was a bad idea since the C7 emblems were significantly harder than the C5/C6 dot material and it would just create a mess or damage the glass. My tint guy knew just how to deal with them and they came out perfect (he asked me not to reveal his secret since he spent so much time perfecting it). He has done many Corvettes, including C7's and has 40 years of experience so I trusted his judgement.
Here's a shot of my rear glass (sorry about the dust).
ArtClassShank's Avatar
ArtClassShank
Black vinyl is the way to go. Adhesion to the dots is always going to be poor, and not worth the effort.
Old Jun 2, 2020 | 03:23 PM
knewblewkorvette's Avatar
knewblewkorvette
Black vinyl on top, tint below
Old Jun 2, 2020 | 04:12 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
i went through this mess years, ago. I went, to many tinter's, and
they never, gave me, the right answer. I, finally found, a tinter, that
knew his business. He used, a piece, of vinyl, and ,it worked out well
I have had it on, for 10 years, in the Florida sun...no problems.
Good luck
Old Jun 2, 2020 | 06:45 PM
Car Rookie's Avatar
Car Rookie
I painted the dot-matrix flat black.
Old Jun 2, 2020 | 07:10 PM
Ed Ramberger's Avatar
Ed Ramberger
Old Jun 3, 2020 | 07:01 AM
Ramets's Avatar
Ramets
Could someone post a pic of the black vinyl strip.
Old Jun 3, 2020 | 09:33 AM
jjc508520's Avatar
jjc508520
What launched me on this journey was that I had the front windows done in my 2016 4runner - and my left arm was really pleased when I put the window up on a sunny day. And the AC in the C5 is marginal - even when working - so I figured the tint would be a good idea (and look good on a Pewter car) - but I did lose the $30 I paid for that hard-to-find "GM Roadside Service sticker" on the drivers door Anything on the insides has to be removed or they won't warranty the work.
These guys also offered to tint the windshield! They said it would block all the UV and be so light as to not be noticeable - almost went for it but figured it would mess up the HUD - even though they said it would not...
Old Jun 4, 2020 | 09:28 AM
slvr bulit's Avatar
slvr bulit
Black vinyl on top
Old Jun 4, 2020 | 10:19 AM
ssmuff's Avatar
ssmuff
2021 C5 of the Year Finalist - Unmodified
Just had my windows tinted with 15% Avery Dennison and I don't have the dots. Pretty pleases with how everything came out. $225
Old Jun 4, 2020 | 10:26 AM
ericba's Avatar
ericba
I would love to see some pics if possible...
Old Jun 6, 2020 | 12:38 PM
ssmuff's Avatar
ssmuff
Side view. 15%
Dots but hardly noticeable.
Read 15%
To Rear window tint
