Crank Pulley C6
Old Jun 6, 2020 | 01:28 PM
quemqn71's Avatar
quemqn71
Default Crank Pulley C6
In my C6 the crank pulley has a severe wobble. Should the harmonic balancer be replaced also. Dealer wants $1400 to fix it.
Old Jun 6, 2020 | 01:44 PM
feeder82's Avatar
feeder82
The crank pulley and harmonic balancer are the same part. And if you have a dealer replace it yes it will cost that much. Try and find a Corvette specialist shop to get a price. And this is the C5 forum but no difference in your repair
Old Jun 7, 2020 | 07:29 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
I am unaware if GM corrected the design, but check the C6 forums for historical issues with the balancer coming apart as yours did. It has been a common fix on C5s. Often, an aftermarket piece is determined to be the most sensible replacement for long-term function.
To Crank Pulley C6
