Did not have the sticky problem but from what I read on previous post, the cause may be from using some protectorates that chemically react to the covering. I only use a soft hand soap and water solution to clean the interior. No protectorates.
it’s actually outgassing of chemicals from the airbag vinyl which is a different vinyl. Again, the lemon ammonia trick worked perfectly, using clean rags to wipe it on/off.
Today I tried glass cleaner (trade name omitted) on my 04 which seemed to work temporarily but the stickyness returned in a few minutes. Maybe it was the diiuted ammonia in the cleaner? So, this did';t work for me - will try lemon ammonia next to hopefully get a permanent fix before moving on down the list. I'm wondering if there's a clear spray we could coat the sticky surface with - more thoughts? I've written the "Tech Nerd" column at Corvette Magazine, who may be familar with a solution. I wonder if someone at the assembly plant or maybe from the airbag manufacturer has anything on this from days gone by?
you need liberal amounts of ammonia and a lot of clean rags as the stickiness must be removed, not just spread. I did mine two months ago and it still looks great. You can’t put anything on the wheel to prevent it as it is outgassing from the vinyl.
