Raising the C5
Old Jul 12, 2020 | 12:30 AM
Richard Jinderlee's Avatar
Richard Jinderlee
Default Raising the C5
I see videos on loweing the C5 on stock bolts. I wish to raise my '04 Z06 CE. Can this be done on stock bolts?
Old Jul 12, 2020 | 12:45 AM
jdmvette's Avatar
jdmvette
Night Owl for life
you should be able to raise it in the rear by tightening down the bolts. I believe the front should raise if you back off on the bolt. (loosen)
Old Jul 13, 2020 | 07:43 PM
Hitman227's Avatar
Hitman227
Hmm Interesting
Old Jul 14, 2020 | 08:19 PM
Big_Mike_SD's Avatar
Big_Mike_SD
Veteran: Marine Corps
St. Jude Donor '21
As viewed from above, it's tightening for both front and rear. For the rear, tighten the nut and bolt. It helps to jack up the rear by the center cradle to make it easier to adjust the adjusting nuts/bolts.
For the front, you will need to make some clearance between the control arm and the rubber pad on the bottom of the adjuster at the end of the leaf spring with either the special tool or a jack and a block of wood, and then you can go rightey -tightey on the 10mm at the top of the threaded adjuster to raise the front.
I posted specifications and measurements for ride heights and trim in another thread.
Old Jul 14, 2020 | 11:51 PM
Richard Jinderlee
Well, the rear went smoothly. Not so the front. The adjusting bolts are are frozen. I even went out and bought a six point 10mm socket and could tell it was going to spin on the bolt. I am going to remove the leaf spring and deal with them on the workbench. I dare not attempt to heat it for I will certainly ruin the composite leaf spring. Any ideas on how I might loosten the adjuster bolts?
Old Jul 15, 2020 | 12:09 AM
BT1991's Avatar
BT1991
/\ same issue with mine. locked solid!!
Old Jul 15, 2020 | 10:47 AM
captaineddie's Avatar
captaineddie
How much are you trying to raise your car? I'd like to raise mine so that I don't scrape when going in and out of my steep driveway.
Old Jul 15, 2020 | 11:02 AM
Richard Jinderlee
I'm not sure how much, at least an inch. It will have to be a compromise between looking "cool" and resembling an off- road vehicle. But first I will have to free-up the bolts. I'll keep you posted.
Old Jul 15, 2020 | 02:44 PM
Richard Jinderlee
Well, I was able to break the bolts free and here is how I went about it. `I removed the leaf spring- it is a relatively easy job. There are two videos on YouTube that address this. One is by "Froggy" and the other is "Scruf's Garage". The control arms on one side (I picked the driver's side) have to be removed. Froggy removed the ball joint whereas Scruf removed the control arm to chassis bolts. I chose the latter method although I removed both the upper and lower control arms and pulled the entire assembly out. This made removing the leaf spring a snap. Make sure you mark the position of the cam washers on the lower control arm. When I had the spring on the bench, I carefully wire brushed as much of the rust on both sides of the bolts as I could reach and hit them with penetrating oil. Where the bolts contact the spring, there is a rubber pad backed by a thick washer. The washer is part of the bolt and I put a fairly large pipe wrench on it and it broke free. I carefully worked the bolt back and forth wire brushing the threads and applying anti-seize until I was able to remove it without damaging the female threads. I am going to replace the bolts- the rubber pad is in poor condition.
Old Jul 15, 2020 | 06:11 PM
BT1991's Avatar
BT1991
How long would you say it took to remove the spring?
Old Jul 15, 2020 | 07:28 PM
Richard Jinderlee
Now that I've done it, 2 hours to remove- I have a lift. The problem facing me now is finding OEM quality adjusting bolts. Fortunately they are available from chevy. Unfortunately they are only available as part of the spring assembly (How thoughtful of them).The aftermarket ones look cheap.
Old Jul 15, 2020 | 07:44 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Pretty common issue, unfortunately
Old Jul 15, 2020 | 08:56 PM
Richard Jinderlee
VMS Racing makes an "articulating" stainless adjustinng bolt. Anybody have experience with this item?
To Raising the C5
