C5 2003 replacement chip keys
Old Jul 25, 2020 | 04:03 PM
JungleClare's Avatar
JungleClare
Navigator
Default C5 2003 replacement chip keys
I need to purchase a replacement (chip) key for 2003 C5 cpe
Please advise me on how to get one?
Old Jul 25, 2020 | 04:52 PM
DDaaryl's Avatar
DDaaryl
Most any good locksmith can copy one of yours. I had mine done for $23.
Old Jul 25, 2020 | 05:07 PM
rrwirsi's Avatar
rrwirsi
Dealership or vendor.
Vendor:: Ecklers Corvette Ignition Keys And Locks.
You will need to measure the resistance on the VATS Pellet to order the right one.
How to read your VATS Pellet Number! - McGuire Lock
Old Jul 25, 2020 | 05:28 PM
MetalMan2's Avatar
MetalMan2
I purchased a blank key online with the right VATS value, and brought it to a local locksmith to cut.
I actually took it a step further, following this post:
https://www.corvetteforum.com/forums...post1597614808
Which uses this:
https://www.ebay.com/itm/362347128596?ul_noapp=true
Still need to buy a key blank, but it can be the cheapest one. Then a tiny bit of modification for an awesome result.
Old Jul 26, 2020 | 11:50 AM
bc6152's Avatar
bc6152
If you have a duplicate key with a chip, just take it to any locksmith facility. They can measure the chip resistance with a machine that they already have and cut you a perfect match. No dealer for $100.00 and Eckler's is always overpriced. Cost me $25.00... GOOD LUCK!
Old Jul 26, 2020 | 11:59 AM
As mentioned, you have a number of options. Perhaps the easiest would be a locksmith. Be prepared to show a number of documents to prove you are the owner of the vehicle or you may not get a key cut.
Old Jul 27, 2020 | 04:40 PM
GCG's Avatar
GCG
If your current key works fine turning the lock cylinders, you can make duplicates:
  • Using a multimeter, measure the resistance of your key pellet.
  • Check the chart below and find the corresponding VATS No.
  • Buy a blank with the correct VATS for your car (Google will help you )
  • Make a duplicate in the place of your choice
Old Jul 27, 2020 | 05:03 PM
aclassicnut's Avatar
aclassicnut
Veteran: Marine Corps
Veteran
I ordered one at our local GM/Chevy/Cadilliac store......................to the tune of 74USD and gave me the key code and cut from the orignal key
I wont do that again.......lesson learned
Old Jul 27, 2020 | 05:21 PM
StickTail's Avatar
StickTail
I measured my VATS value and bought the right key on ebay. Took it to chevy dealer and they totally fucked it up. Next time I will go to a professional.
Old Jul 27, 2020 | 06:47 PM
DinoBob's Avatar
DinoBob
STRATTEC makes a GM-identical replacement for these, factory appearance, which is important to me. Even the 50th key. Measured mine, ordered the right value, and the guy at Home Depot cut them for me at no charge.
To C5 2003 replacement chip keys
