Culvert-1 C5-0
Old Jul 29, 2020 | 10:54 PM
Chaserz1's Avatar
Chaserz1
Default Culvert-1 C5-0
Welp decided to run up to meet the wife for dinner at the wing spot. Coming around a bend and the back end stepped out, corrected once and flicked back counter clockwise. Was just lucky enough there was a culvert that spun me back around or else the whole rear end would’ve been into a pole.
Only real damage I have found so far is the rear wheel (of course) and a spot on the passenger side skirt. Picking up new wheels in the morning. Hopefully black z06.
Nothing in the rear end looks bent, cracked, shifted out of place. Im hoping the bottom lip of the wheel and it breaking took most the force and not my diff and axle. The cradle bolts and everything else seem to be straight and not bent over at all. Drivers side looks to be straight and nothing is shifted. The rear bumper went right back to its normal position once we pulled it out.
Hopefully got really lucky but will update tomorrow.
Old Jul 29, 2020 | 11:05 PM
Life’s good C5's Avatar
Life’s good C5
Yikes! Glad your ok. I’d pass on the wings next time. JK.
Old Jul 30, 2020 | 08:36 AM
MadMax96's Avatar
MadMax96
Looks like the result of someone leaving a car meet on YouTube! Glad you're ok - could have been way worse.
Old Jul 30, 2020 | 08:50 AM
Chaserz1's Avatar
Chaserz1
Yeah probably looked just like that. Wet road and old run flats don’t mix. Picking up black z06 replicas this morning. 315/30r with Michelin’s
Old Jul 30, 2020 | 09:55 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Amazing how the spokes of the wheel blew off. Probably saved you from damaging the suspension. At least no one got hurt.
Old Jul 30, 2020 | 10:04 AM
Chaserz1's Avatar
Chaserz1
when I went back and looked where the car slid it just barely caught the lip of the culvert with the wheel. I’m glad I wasn’t fully down in the ditch and caught the center of the wheel and body panels
Old Jul 30, 2020 | 11:39 AM
knewblewkorvette's Avatar
knewblewkorvette
I've never seen a rim do that before.
Old Jul 30, 2020 | 01:16 PM
Chaserz1's Avatar
Chaserz1
Well got the wheels and tires on. Rolled it down the driveway and wheel doesn’t seem to roll out of wack at all. Drove down the road up to 30 and no drivetrain noise at all, vibrations, about to head to the alignment shop now.
Old Jul 30, 2020 | 01:32 PM
knewblewkorvette
Probably wouldn't hurt to get an alignment because of the mishap and the new wheels.
Old Jul 30, 2020 | 02:59 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Old Jul 30, 2020 | 03:18 PM
FOGeologist's Avatar
FOGeologist
You are really, really lucky.
I once rounded a corner in a rental BMW 3-series in the snow at like 3 mph. The car slid sideways into the curb, which utterly destroyed the rear suspension.
Had to have it towed.
I owned a 3-series BMW coupe, which had the rear-end tear out the body mount. BMW fixed it under warranty - with 42 miles left, LOL.
Corvette rear suspensions must be STRONK LIKE BULL!
Old Jul 30, 2020 | 03:28 PM
Chaserz1's Avatar
Chaserz1
lol yeah I think I was just able to hit it just right on the rim so that it broke away and saved everything else.
I think these 315/30 have too low of a side profile. My wheel gap is crazy now. I’ll need to replace all the tires on the new wheels anyways
Old Jul 30, 2020 | 04:09 PM
tikiman's Avatar
tikiman
You could try lowering the car.
Old Jul 30, 2020 | 08:12 PM
Chaserz1's Avatar
Chaserz1
I am already lowered on stock bolts now. May go aftermarket bolts but I’m looking at new tires anyways. 315/35r18 Toyo TQ will put me back about stock with 26.6” tall tire.
Old Jul 31, 2020 | 09:40 AM
rpm462's Avatar
rpm462
Wow...glad you're OK!! Hope the repairs are minor and inexpensive.
Old Jul 31, 2020 | 10:28 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Glad things turned out okay.
Old Jul 31, 2020 | 11:01 AM
Chaserz1's Avatar
Chaserz1
[QUOTE=rpm462;1601933316]Wow...glad you're OK!! Hope the repairs are minor and inexpensive. [/
Yeah it’s on the alignment rack right now. Everything is looking good and nothing bent. Just some minor fiberglass work on the rocker panel and front fender liners. Found most the parts plus some others I might as well replace that need it on vettenuts.
To Culvert-1 C5-0
Old Jul 31, 2020 | 12:38 PM
Bet that caused a real pucker factor. Sure glad you are OK and good luck with the repairs.
Old Jul 31, 2020 | 12:44 PM
tzeller's Avatar
tzeller
Sorry that happened to you. Thankfully you were not injured and the car did not sustain much damage.
Old Jul 31, 2020 | 12:50 PM
Chaserz1's Avatar
Chaserz1
oh yeah. Especially when I saw the telephone pole coming and somehow missed it but inches, but seeing the car on the trailer now with the z06 wheels makes me want to just start ordering the parts
