Weird Sound
Old Aug 9, 2020 | 09:00 PM
thetikm's Avatar
thetikm
7th Gear
Default Weird Sound
My car has been running great for the past year. I started it home to go home from work today and it's making a new sound. I believe it might be a bad lifter. A very rhythmic slapping sound coming from around cylinder 2. I took of the valve covers and the valve springs looked normal, no sludge whatsoever, no play in the rocker arms. I took the belts off and it didn't change. Oil pressure is above 40 psi.
Any ideas? I'm gonna do a compression test tomorrow
Old Aug 9, 2020 | 11:10 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I’d say you missed the broken valve spring otherwise a lifter issue.
