decent LEDs to replace front headlights?
Old Aug 10, 2020 | 05:45 PM
JMG2's Avatar
JMG2
Moderator
Default decent LEDs to replace front headlights?
thinking of doing a LED replacement, anyone have any recommendations? looking to retain stock housing.
Old Aug 10, 2020 | 05:58 PM
Autoeng's Avatar
Autoeng
I'm quite happy with these for $32. Low beams same brand. No one has flashed me yet for being too bright or scattered.
Note that changing to LED's will not draw enough juice to lower the headlights when the car is off. Just lower them while the car is running.
https://www.amazon.com/gp/product/B01MTJSLI5/ref=ppx_yo_dt_b_asin_title_o07_s01?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01MTJSLI5/ref=ppx_yo_dt_b_asin_title_o07_s01?ie=UTF8&psc=1
I also changed the fog lights to these. After turning the aim screw 4 times clock wise I can now get some use out of them. Past dawn and early evening I can use them instead of the headlights. $37
https://www.amazon.com/gp/product/B06XHF7YVR/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B06XHF7YVR/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
Old Aug 10, 2020 | 06:21 PM
jdmvette's Avatar
jdmvette
Night Owl for life
I have these as my low beams
https://www.boslla.com
Not cheap at all but I dig the 3000k option I use around dusk & dawn
Regular 6500k led is nice and bright as expected for normal night time driving
Old Aug 10, 2020 | 08:51 PM
MikeyMcFly's Avatar
MikeyMcFly
9012 HIR > LED.
Outside of the Hikari Ultra LED bulb most LED bulbs are significantly outclassed by performance halogen bulbs. Yes, LED gives a ton of short range foreground light. It’s not good for distance and does not help your driving.
A member of a forum I’m on has done extensive testing of a significant amount of headlamp bulbs including halogen and LED and only the Hikari Ultra are worth anything.
https://www.tacomaworld.com/threads/...lights.589465/
Jalopnik recently did a similar article with the same results consulting with Daniel Stern lighting.
https://jalopnik.com/why-most-led-he...-ex-1843070472
I run Vosla 9012 HIR low beam bulbs and are pleased with them. Do they have the same color and clarity of my RadioFlyer ACAs, no, but they have none of the drawbacks either.
Last edited by MikeyMcFly; Aug 10, 2020 at 09:24 PM. Reason: Phone autocorrected a bunch of stuff that didn't make sense.
Old Aug 11, 2020 | 07:49 AM
JMG2's Avatar
JMG2
Moderator
Originally Posted by MikeyMcFly
9012 HIR > LED.
OK, so what's the best upgrade to the existing lighting? replace the bulb with 9012 HIR s?
Old Aug 11, 2020 | 10:07 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
https://www.corvetteforum.com/forums...n-or-ebay.html
Been happy with my MOSTPLUS LED headlight bulbs.
Old Aug 11, 2020 | 10:37 AM
mkraffert's Avatar
mkraffert
St. Jude Donor '20
9012 HIR > A member of a forum I’m on has done extensive testing of a significant amount of headlamp bulbs including halogen and LED and only the Hikari Ultra are worth anything.
The Hikari Ultras are great bulbs, but they have a very short lifespan. I have them on my F150 and they are outstanding performers, but I've had the truck 3 years, and I'm on my 3rd set. They're worth tolerating the short lifespan for the performance they offer though.
Old Aug 11, 2020 | 10:41 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
IMHO the BEST option is the radioflyer ACA headlights from Sharp Light Innovations. However, these do not keep the stock housing, and they certainly are not cheap. Any LED you put in the stock housing will result in a very scattered light pattern. The stock reflector just wasn't designed for LEDs. With that said, I ran with LEDs for over a year before upgrading to the ACA recently.
Old Aug 11, 2020 | 11:56 AM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I love my diode dynamic bulbs, not very cheap either. Mine are still in the stock housings but I plan on changing out sometime to the ACA housings.
Old Aug 11, 2020 | 12:42 PM
VetteHunter79's Avatar
VetteHunter79
https://www.ebay.com/itm/163826032986
These are what I went with. Can’t beat the price and they are a lot brighter than the factory. You can see the difference in the driver side being factory bulb and passenger being the LED.
Old Aug 11, 2020 | 02:47 PM
jjc508520's Avatar
jjc508520
Aren't most going with HID on the low beam and LED on the high beam?
Old Aug 11, 2020 | 09:49 PM
mic575's Avatar
mic575
I went with the 9012 HIR modification. It met my cost/reliability desires for now.
To decent LEDs to replace front headlights?
