1998 C5 Center console
Old Aug 22, 2020 | 12:10 PM
hotfrank's Avatar
hotfrank
Default 1998 C5 Center console
Inside center console near USB connectors there is a blue light. Should this light stay on at all times?
Old Aug 22, 2020 | 12:39 PM
redzg's Avatar
redzg
If you have USB connectors anywhere they are not original, and more than likely neither is the blue light. Post a picture of the connectors and light if you would, and it will help with identifying what's going on. Double din console by chance? The USB should be driven by the head unit, but perhaps the blue lights are connected to the previous cigarette lighter outlet, which was full time power.
Old Aug 22, 2020 | 09:33 PM
hotfrank's Avatar
hotfrank
Old Aug 23, 2020 | 06:14 AM
jdmvette's Avatar
jdmvette
Night Owl for life
The cigarette lighters in the C5 are always hot and not switched with the key like many other cars.
Old Aug 23, 2020 | 08:53 AM
JMG2's Avatar
JMG2
Moderator
c5 didn't come with USB connectors anywhere, prior owner must have put it in.
If connected to the old 12 volt receptacle lighting, it'll always be on. shouldn't really drain your battery, but I'm not a fan of any drain when the car is off, may want to replace it with one that doesn't have an Led.
To 1998 C5 Center console
