You have a 16yo car that has hardly been driven. I don't care what kind of car it is, you're going to run into issues if it's that old and driven that little. Most of the issues that you described are somewhat common and pretty cheap and easy to fix. I suspect they've popped up all at once, because you're actually driving the car, and the previous owner just let it sit. Use the resources on this forum and YouTube to fix these issues yourself, and learn how to better prevent other ones from happening. You'll learn more about your car, and gain a better appreciation for how durable and reliable these cars are after 16+ plus years.
I agree. Every car starts having issues after a while
Use YouTube as previously stated. Most all those parts are affordable.
Your issues appear to be minor knick knack kind of stuff. Any 20 year old car, I don't care what kind, will need work from time to time. But it's worth it if you're planning to keep It for the long haul. For instance, my original AC compressor went out. It wasn't cheap to fix, but the new one should be good for another 12-15 years.
Exactly. Parts that fail in a 20 year old car means it's basically time for them to have issues. Remember...it's over 20 years old. If it lasted that long then once you fix it then you're good basically for the rest of the time you have it. I know you're upset about the car having issues but it's a 20 year old car and like we've said, those fixes honestly aren't bad and once you fix it then you're golden pony boy.
I bought a 1999 three years ago. Several problems have come up but really were not a problem because I could fix it myself. Biggest issue was harmonic balancer but even that was a $200 problem because I replaced it myself. Some things like electrical switches are more of a problem because of non use. Mice filling the blower with Kleenex is not a good thing either. I really didn’t fault the car but blamed it on the way I use it. (Stored during Michigan winters.) If you drive an old car and use it sporadically, you are going to have some issues. With the help of members on this forum and videos online even moderately handy individuals can do most repairs.
I've owned my '99 for 2-1/2 years and 12K miles. Have had a few similar issues. They may have been a little annoying, but never discouraged me from owning the car. In most cases, this forum was extremely helpful and one of the top reasons I like owning a Corvette.
TPMS sensors
oil pressure sending unit
climate control dim repair
fuel line check valve
hood, deck lid, and trunk struts
driver window regulator
LMC5 module
learning that it's best to keep it on a battery tender when driving it
Hang in there. From what I read, you've got the most desirable year for a C5.
Most 20 year old cars with most these kind of problems would just leave it alone and keep on driving it until it goes to the junk yard. Corvettes are different in that most owners will fix them and hold on to them for years longer and then when they do sell they still get a good price for them.
I really regret selling both of my past C5s, they were great cars though some jobs were involved, like seperating the entire drive from the body to replace the clutch......
But it was the journey as much as the destination.....
I've had my 2004 CE Coup with 34k miles for almost two years now.
Here's the problems I've had SO FAR.
1. Pop up headlight not working.
2. Battery died three times.
3. Tire Monitor System needs serviced.
4. Sometimes the hood wont latch.
5. Driver side window wont roll down.
6. 12 disc cd changer broke because I switched between discs too fast. How the xxxx was I supposed to know you have to go slow when doing this?
7. Gear shifter under car broke and had to be fixed.
8. Now my sound system is not working properly ever since I was messing around in the fuse box trying to fix my broke cigarette lighter.
This is insane. Before I got this car I drove a 94 Z28 for 20 years and never had this many problems.
I can not recommend anyone buying a C5 Corvette.
I can recommend that you do not own a Vette. Go back to your wanna be Camaro.
That is everything said that needs to be said in a nut shell. A C5 is meant to be worked on, and modified, at this point in it's history as a performance car. The work I have done on my car, including clutch, TT Rebuild, new fuel sending units, new heads, cam, intake, all new front engine accessories, stereo, bolt ons, etc. would have well over $12k had I not done them myself. If something doesn't work on a car it set's me into an OCD tail spin - so my car is 100% functional and working as everything should. But working on the car and making it perfect is 50% of the fun of the car.
If you are intending to buy a used car to drive while a shop maintains it, maybe a C5 isn't for you. There is a late model C6, or even maybe a C7, with your name all over it that will require a hell of a lot less maintenance.
i agree. I am having a blast rebuilding mine and making it really unique. I love to tinker. I also love to shift. Perfect car.
I have many people (including my two boys) tell me they want a Corvette after seeing mine. And one of the first things I tell them is, unless you know how to work on cars, it's probably not for you.
I researched these cars to death before I bought mine, and knew what the possible upcoming malfunctions might be (The balancer was already on its' last legs). I was not concerned with the cost of these possible repairs, as I do my own work. If you pay the going rate for a C5 and can't do your own work you should (eventually) be prepared to have more money in the car that you'll ever see back (if that's a concern).
I enjoy this kind of work. Just this year I've replaced the a/c compressor and the balancer at parts-only cost. I never would have bought my car if I couldn't repair it myself. To me the whole idea of owning the car is having the most fun at the least cost. Just my opinion.
or if it is really screwed up, https://corvettesalvage.com/product/...ice-1997-2004/ but that is expensive, best to go with aftermarket head unit.
7) Not sure what you are referring to.
8) see #6, just put in aftermarket stereo.
Originally Posted by bonesbrakr
If its green id go to $2,150. OH NO!!! Did i start a bidding war? It might get up to $2,400.
I'm in at $2,151. The Price is Right!
Ope, just say it's a CE. I'll go straight to $2,400!
