cd player
Old Aug 24, 2020 | 12:27 PM
Black76's Avatar
Black76
Default cd player
I have a 99 it has the 12 cd changer in the truck the disk holder is stock and will not eject from player is there a way to maualy get it to eject
Old Aug 24, 2020 | 03:52 PM
rrwirsi's Avatar
rrwirsi
Maybe some gentle tapping on the changer frame will 'encourage it' to eject. Also, check the fuse.
Old Aug 24, 2020 | 04:00 PM
BOBS40th's Avatar
BOBS40th
I have a 2000 with the same problem don't know what to do about it.
Hope someone has a fix for it.
Old Aug 24, 2020 | 04:38 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
This should do it!
Old Aug 24, 2020 | 05:06 PM
vettpapaw's Avatar
vettpapaw
Mine did the same thing, I took mine out and took the cover off. There was a disc jammed inside. Pulled out the disc and it works fine. If I remember correctly it was a 45 minute job.
Old Aug 24, 2020 | 05:50 PM
Denny Kohlman's Avatar
Denny Kohlman
I never had a CD not come out of my corvette but last weekend my 03 Silverado would not eject the CD. Easy fix. I took a shim that you use to shim doors or windows and wrapped the end with double faced tape. Start at the thin end and wrap it around the long way. Cut off and excess on the sides. Put the thin end in the CD changer and push down. It will grab the CD and come right out. You don't have to push down very hard. It took me longer to make the tool than to get it out.
To cd player
