Tires on backwards
Old Aug 31, 2020 | 04:12 PM
Trickrick69's Avatar
Trickrick69
8th Gear
Default Tires on backwards
Owned my 2004 for about 6 months. Had brand new Michelin Zero pressure tires. Just discovered the rear tires are on opposite the rotation arrows. Should I swap left to right or just leave them as there already broken in with 8,000 miles. My fault for not checking but I'm 70 years old and getting down to check the tires is a major chore.
Old Aug 31, 2020 | 04:16 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I would definitely swap them! the tread will not work correctly the way you have them. I suspect if you ever drove in the rain, you'd lose control.
Old Aug 31, 2020 | 04:21 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
curious.....are the TPMS working correctly? by that I mean is the reading correct for each tire? or are they working but the pressure for RF is actually the LF etc.
Old Aug 31, 2020 | 04:35 PM
Trickrick69
8th Gear
Rear tires on backwards. TPMS working ok as all tires read correctly when warmed up. My concern is , if I corrected the rotation after 8,000 miles the tires may fall apart. I did make a 4,000 mile trip and drove in the rain with no issues. Looking at the tread, its obvious rain wouldn't be dispersed properly. Maybe I was just lucky.
Old Aug 31, 2020 | 04:50 PM
pewter99's Avatar
pewter99
switch them:
A directional tire is, quite simply, a tire that is engineered to roll in only one direction. ... If mounted incorrectly, a directional tire cannot be expected to work properly in wet or wintry conditions. If mounted improperly, directional tires may also wear irregularly and prematurely, and produce excessive road noise.
Old Aug 31, 2020 | 05:21 PM
CJ Willys's Avatar
CJ Willys
I would simply swap sides
Old Aug 31, 2020 | 06:35 PM
Trickrick69
8th Gear
Originally Posted by pewter99
switch them:
will I damage the tires since after 8,000 miles the tires are broken in backwards. By changing rotation, I'll be reversing the direction of stress on the tire plys.
could this cause ply separation?
Old Aug 31, 2020 | 07:19 PM
BT1991's Avatar
BT1991
/\ No
Old Aug 31, 2020 | 07:31 PM
Just swap the tires. They will be OK.
Old Aug 31, 2020 | 07:39 PM
Trickrick69
8th Gear
thanks all. Believe my question has been answered.
Old Sep 1, 2020 | 08:00 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It appears that the tire shop that you did business with, made a mistake. It also appears that you're quite concerned about any potentially negative consequences, in swapping the tires, so they're mounted correctly.
I suggest that you go back to where you bought them, make them swap the tires, and have them address any concerns you might have, going forward, about the tires being incorrect, for so long....
Old Sep 1, 2020 | 11:58 AM
knewblewkorvette's Avatar
knewblewkorvette
As you can see, this is a directional tire. Having it backwards, it will not channel out the water when it's raining out. In fact, it will do just the opposite, it will channel in the water in creating a dangerous hydroplaning condition.
Also, rotation of the tires to the opposite side will not hurt the tires at all. With most cars, rotation is part of regular maintenance.
Old Sep 1, 2020 | 12:07 PM
Trickrick69
8th Gear
Great and thanks for helping. I'm going to swap left to right.
Old Sep 2, 2020 | 02:24 PM
jackthelad's Avatar
jackthelad
And reset the TPMS system. That way you can be sure the "left" pressure reading is from the left wheel, etc.
Old Sep 5, 2020 | 06:06 AM
10thumper's Avatar
10thumper
Drive on the freeway in reverse for 100 miles then switch them over you’ll be just fine. Kidding, don’t worry about it because if this was an issue we could only turn left like NASCAR.
To Tires on backwards
