Spark when reconnecting battery
Old Sep 10, 2020 | 09:43 PM
Extoncorvette's Avatar
Extoncorvette
2nd Gear
Default Spark when reconnecting battery
I have a stock radio on my 2002 C5, so I just started installing a Double Din Pioneer DMH-2660NEX. Once I was done with the install, I went to reconnect the negative side of the battery and I’m getting small sparks almost every time. Has anyone else experienced this? I ordered all of the parts from Crutchfield, and even ordered the ReadyHarness so I didn’t have to mess around soldering anything, but do you think I may have missed a connection which is causing the battery to spark? I’m nervous to continue trying to connect the battery because I don’t want to fry anything, including myself!
Old Sep 10, 2020 | 09:51 PM
chevyorange's Avatar
chevyorange
I've owned many cars in my life and have had this happen on the majority of them. I'm not saying it is normal but I've never had them have an electrical failure.
I'm sure it is caused by some kind of ground or loop in the system. That's the extent of my expertise. Hopefully someone more adept pipes in.
Old Sep 10, 2020 | 11:15 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
Anytime I connected a car battery I almost always noticed a spark. There is always somw inrush current when things turn on. Considering how sensitive these cars are to low voltages I wouldn't continue to do this. Just connect the battery cable and leave it on. It you were getting a large spark like a short, I would worry about it.
Old Sep 11, 2020 | 09:18 AM
helga203's Avatar
helga203
Any car that has computes will have an immediate draw of power to turn on and that's the spark you see. I've disconnected my battery and friends hundreds of times overs the 20 years of owning it. Manny many upgrades and broken parts over the years. Well that's my experience.
Old Sep 11, 2020 | 09:53 AM
knewblewkorvette's Avatar
knewblewkorvette
I find that to be the norm for me hooking up a battery. You will get the tiny sparks and a crackling sound.
Old Sep 11, 2020 | 09:55 AM
RichyB33's Avatar
RichyB33
Perfectly normal. Complete the connection and tighten it down.
Old Sep 11, 2020 | 11:01 AM
Had that happen many times also. Normal as far as I can tell.
Old Sep 11, 2020 | 11:02 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 11, 2020 | 04:59 PM
Extoncorvette
2nd Gear
Thanks to everyone for the replies; I taped up my wrench in electrical tape, put on a pair of rubber gloves and tightened the nut as it crackled and sparked a little. No issues at all and I love my new stereo.
Old Sep 12, 2020 | 10:39 AM
Carmine97's Avatar
Carmine97
Cruise-In I Veteran
BTW, this is also why you always, ALWAYS connect ground last!
This also applies to jump starts.
You will always get a spark when connecting the last terminal.
If the last one is positive, the spark surge may take out an electronics module.
That's the start of a really bad day.
Spark surges on the ground side seldom cause any problems.
Old Sep 12, 2020 | 10:59 AM
helga203's Avatar
helga203
Sorry
Old Sep 12, 2020 | 11:11 AM
JMG2's Avatar
JMG2
Moderator
Totally normal.
To Spark when reconnecting battery
