power chips
Old Sep 18, 2020 | 07:15 PM
jarv33's Avatar
jarv33
Default power chips
has anyone used the 3 stage power chip on their c5??
Old Sep 18, 2020 | 07:16 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
No such thing as a "power chip" on these cars. Whatever it is, it's bogus. I 100% guarantee it.
Old Sep 18, 2020 | 07:36 PM
BLUDICE's Avatar
BLUDICE
So all these guys we see ads and commercials are scams? For real?
Stingroo's Avatar
Stingroo
...yes.
Old Sep 18, 2020 | 07:49 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
The early GM ECMs used a PROM chip (Program Read Only Memory IIRC). The chips contained the fuel maps, timing maps, etc. The aftermarket started making performance chips to wring out a little more power. The chips were physically replaced in the ECM to accomplish this. At least since the beginning of C5 production, maybe a bit earlier but not sure on that, the ECM itself became programmable (aka getting a tune). With the right equipment, you could access the ECM and customize many of the tunable parameters. There is no "chip" to replace in these ECMs.
Old Sep 18, 2020 | 07:58 PM
Don’t waste your money - power chips do not work well on a C5. Just get a tune and you will be much happier - especially if you do so after adding some power mods.
Old Sep 19, 2020 | 07:51 AM
BLUDICE's Avatar
BLUDICE
So what would be a “tune” on a stock C5? For example.
Old Sep 19, 2020 | 07:53 AM
Stingroo's Avatar
Stingroo
Go to a dyno shop in your area. They can adjust many parameters on these cars - torque management, automatic transmission line pressures, adjust for tire size/gear changes, clean up the fuel tables, disable the low speed fuel cutoff, etc.
There's a lot of adjustability in these stock LS PCM already. Anything that claims to plug in to your car and give gains is snake oil.
Old Sep 19, 2020 | 08:33 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
Been tuning for years on my own modified cars.
If you are bone stock, there typically is not too much to change to make a major difference in seat of the pants power. Tuning can take care of the skip shift with manuals and can tweak the shift points and firmness of automatics if you want it a to shift less "slushy". The minor tweaks to fueling and timing will not add a material amount of HP that you will feel on a stock C5 - IMO.
If you do decide to have your car "tuned" find out who the reputable tuners are in your areas. There are quite a few good ones and a few I wouldn't let touch my rig. It is up to you to do some due diligence and find out who is who...
Good luck,
Toys
Old Sep 19, 2020 | 09:09 AM
BLUDICE's Avatar
BLUDICE
Good luck,
Toys
What would I expect to pay for a “tune up”?
Stock ‘98 w/auto
Old Sep 19, 2020 | 09:11 AM
Stingroo's Avatar
Stingroo
A tune will run you anywhere from $200-500 in most areas depending on what they do, what mods you have, and if there's dyno time involved.
Old Sep 19, 2020 | 09:56 AM
Toys4Life C5
St. Jude Donor '21
Before you pay for a tune, think seriously about your 5 year plan for the car.
Makes no sense to pay for a tune and then decide in 6 months to do another mod.... and have to pay for another tune...
Old Sep 19, 2020 | 09:57 AM
Stingroo's Avatar
Stingroo
^ Definitely that. Cause there's no bulk discount. haha
To power chips
