Should this be happening
I have had the car 7 years now and everytime I have tried to use meguiars ultimate compound, meguairs ultimate polish, and meguairs jet black/ultimate wax it has been very troublesome to get any type of compound, polish, or wax off of the car. No matter if I let it sit less than 30 seconds or 2-3 minutes before wiping it off. Its not as simple as just taking a microfiber towel and wiping it off. Its basically stuck on. I really have to go over the whole car multiple times with alot of pressure on the towel after applying anything. To better explain this I can scrub and scrub with a microfiber towel lightly dipped in water and its still there.
Here is what I normally use on my C5.
For soap I typically always use meguairs gold class car wash or ultimate car wash.
For wheels and tires I always use meguairs ultimate wheel cleaner.
For leather I use meguairs ultimate leather cleaner.
I stick with meguairs products, because I absolutely love the high gloss shine their leather cleaner does for my interior.
If there is others you'd recommend I am definately open to suggestions if their is a certain wax or compound I should be using on a c5 body.
I guess what I really want to know is... Is it normal for it to take so much effort just to remove any type of compound, polish, or wax off of this car. It seems like the hood, the hardtop, and the trunk itself require a whole lot more effort vs the bumpers and doors. The doors and the front and back bumpers are way easier to remove the wax or polish. Is it normal for this to happen on a 20 year old C5? Its been this way ever since I bought the car 7 years ago.
Also for light scratches on a c5 body which product do you recommend using. I tried meguairs scratch X 2.0 and ultimate compound with a normal polish pad, but I have a scratch that remains. If you run your fingernail over it, its not deep at all.
Thank you in advance for all of your help!
DA is a night and day difference from hand wax/polish and you use a heck of a lot less product.
I use 3d products and HD speed is a very good all in one. If situation really bad then use ultimate compound and then hd speed, of course I clay bar when needed which is rare for me.
again it's a night and day difference with a da machine. I can't believe I waited so long to get one. All because I was afraid of screwing my paint up.
Show us pix
Yes a DA will help apply the products but you need help with removal. First I always apply products with a DA and I always mist the panel with water before applying the product. You can work the product longer and it doesn't dry as much making removal much easier.
Show us pix
sounds like you need paint correction.
The bonus is it's usually about $8-$10 a bottle and I can find it in the automotive section at any store.
I first tried doing it by hand, then I switched to this.
Here is what I have been using. Its a 120v corded 1 amp 3000 RPM buffer/polisher which I picked up at harbor freight for $21.99. Is this not what I should be using?
Its a drillmaster 61898 if that helps. Then I just apply ultra smooth 10" polishing bonnets on it and goto work with ultimate compound.
https://www.harborfreight.com/10-in-...her-61898.html
This is polishing bonnets I use
https://www.harborfreight.com/2-piec...ets-43431.html
The only thing thats bugging me is the ultimate compound won't come off the car. No matter if I buff and wait 20 seconds or 2-3 minutes. It actually makes no difference. Its still stuck on the body.
Where are you located?
Other option is you pay someone to correct the paint ( holograms/swirls/scratches) and either have them seal it and continue on with your current regiment or dive down deep into the detailing wormhole and do it all yourself.
