Need sheet metal screws
Old Oct 9, 2020 | 12:33 PM
Fast one's Avatar
Fast one
Default Need sheet metal screws
I want to replace the factory 3/4" long, #8, Torx drive, pan head, black oxide sheet metal screws with the same specs but in black oxide stainless steel. Has anyone found a source for these?
Old Oct 9, 2020 | 01:19 PM
Autoeng's Avatar
Autoeng
There are several companies that offer SS kits but I don't think any are black.
https://www.pfyc.com/stainless-steel...RoC-jYQAvD_BwE
Old Oct 10, 2020 | 01:32 PM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Use black felt pen marker to cover screw heads?
Old Oct 14, 2020 | 09:50 PM
Tbair64's Avatar
Tbair64
Check McMaster carr. I bought black SS hardware to use on my track spec hood vents.
Old Oct 15, 2020 | 02:20 PM
heggsc5's Avatar
heggsc5
Did you install yours with black nuts/bolts or black rivets? I considered nuts/bolts, but black rivets were already there so I used those.
Old Oct 15, 2020 | 02:37 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
You may find them here:
https://www.fastenal.com/
Old Oct 15, 2020 | 03:15 PM
Tbair64's Avatar
Tbair64
black SS bolts nuts and washers.
Old Oct 15, 2020 | 05:26 PM
Fast one's Avatar
Fast one
The black sheet metal screws I was looking for were the same as the factory used except being stainless steel so they won't rust. I settled on some that use a Phillips drive instead of Torx but they are stainless steel and black oxide coated. Thanks for the replys.
To Need sheet metal screws
