Glove Box Light
Old Oct 11, 2020 | 03:44 PM
captaineddie's Avatar
captaineddie
Default Glove Box Light
I have been changing out the old halogen light bulbs on my 2004 convertible and all went well till today. I pulled out the old bulb in the glove compartment and tried to insert the new LED and immediately had problems. It was hard to get in, so I finally gave up and put the old bulb back in. Now, the light doesn't work at all with either bulb. Do you suppose that I broke the connectors, and if so, can I order a new switch from somewhere? I can't find it listed on any website.
Old Oct 11, 2020 | 04:43 PM
Autoeng's Avatar
Autoeng
Mine did the same thing. I was frustrated. Said screw it, i'll fix it tomorrow, Tomorrow came and opened the glove box and the light was on again. I think there is a timer on it.
Old Oct 11, 2020 | 05:57 PM
captaineddie
I'll check in the morning. Thanks!
Old Oct 11, 2020 | 06:14 PM
Daveinnola's Avatar
Daveinnola
There is a timer on the interior lights. If you leave the door open too long the interior lights go out. My guess would be that the glove box light is on the same circuit.
Old Oct 12, 2020 | 03:06 PM
JimHarris4's Avatar
JimHarris4
I used my wife’s compact mirror to see what was going on in that glovebox. Made changing the bulb simple. Used my iPhone flashlight to see in with the mirror.
QUOTE=captaineddie;1602324590]I have been changing out the old halogen light bulbs on my 2004 convertible and all went well till today. I pulled out the old bulb in the glove compartment and tried to insert the new LED and immediately had problems. It was hard to get in, so I finally gave up and put the old bulb back in. Now, the light doesn't work at all with either bulb. Do you suppose that I broke the connectors, and if so, can I order a new switch from somewhere? I can't find it listed on any website.[/QUOTE]
Old Oct 12, 2020 | 08:45 PM
captaineddie
I checked the light today and it's still not working, so I took the switch out and ordered a new one. Maybe it will work then. I'll report back. Thanks for responding.
Old Oct 12, 2020 | 09:23 PM
punk86's Avatar
punk86
You blew a fuse. I changed my trunk lights, glove box, foot wells under driver and passenger with leds and blew a fuse, now they work.
Old Oct 13, 2020 | 06:12 PM
captaineddie
Well, duh! I feel really stupid. That's what was wrong. Thanks so much!
Old Oct 14, 2020 | 04:31 PM
Hope you can cancel the switch. Good that but was a simple fix.
Old Oct 27, 2020 | 09:00 PM
Kubiak27's Avatar
Kubiak27
4th Gear
Hey guys. I know this has nothing to do with my glove box light but.....my glove box is stuck closed. It seems that the latch works fine however it feels like the ‘hook’ that wraps around the metal grab piece attached to the dash isn’t releasing enough to open the glove box. Has anyone experienced this? And if so, is there something I can do and use to help get the glove box open without damaging the box? Thanks for any help out there.
Old Oct 27, 2020 | 10:53 PM
punk86's Avatar
punk86
You should create your own post rather than hijacking one
To Glove Box Light
