No Dash Lights
Old Oct 12, 2020 | 04:36 PM
yvzoner's Avatar
yvzoner
6th Gear
Default No Dash Lights
Ok, I have a 99 C5 coupe and I just installed a new multi function head light switch but my dash lights still don't work. I have head lights, fog lights, tail lights, blinkers, interior lights and the dimmer **** is turned fully bright. It all started with the dash lights going on then off. Sometimes they would stay on for days and other times they came on then off for a hour or more. Now they are off for good. I have HUD and it works fine. Yes, I have checked and replaced any fuses that were in question and I loosened a tightened the 10 mm nut where the ground wire connects to the frame below the battery. Since I don't have the shop manual or schematic I have come to a halt. Who has experienced this problem and fixed it?
Thanx for any help.
Old Oct 12, 2020 | 04:50 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
You might want to try the tech forum for this one. You've already done all the things I was going to suggest.
Old Oct 12, 2020 | 08:15 PM
Life’s good C5's Avatar
Life’s good C5
You might check the 2 10mm ground lugs that are (1 on each side) on the frame rail at the front of the engine. I only mention these as you stated you checked below the battery and did not mention these.
To No Dash Lights
