HUD install
Old Oct 20, 2020 | 10:33 PM
Bgrimes's Avatar
Bgrimes
Cruising
Default HUD install
Not sure if it's been asked before. But I am thinking of installing an HUD in my 99 FRC. What all would I need to change?
Old Oct 20, 2020 | 11:42 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
It's been asked many times, and it's definitely been completed in other people's C5's....Ask yourself seriously if this is something you want to undertake and HUD is something you can't live without...I have HUD on my 2000, and in the near 17 years I've owned it, I've probably used it 3 times, just to see if it was still functioning.
I'll refer you to this thread....Hopefully, the answers your looking for, will present itself....Good luck
https://www.corvetteforum.com/forums...y-on-a-c5.html
Old Oct 21, 2020 | 08:42 AM
Bgrimes's Avatar
Bgrimes
Cruising
Tha is for the reply
Old Oct 21, 2020 | 09:40 AM
dbgoodwin's Avatar
dbgoodwin
It’s very doable for the average person with patience and any skill. I would recommend driving a car with HUD a few times before committing to it though.
when I first got my Z06 the first thing I was going to do was add HUD. Luckily I drove a car with it before purchasing all the stuff to do it. I would probably use it if I had it, but now that I’ve used it I can 100% live with out it, and spent my money and time on things I enjoy a lot more.
if someone gave me all the stuff to do it, I would consider installing it once I’m done with my 4runner and RX7 projects, because it is really cool.
Old Oct 22, 2020 | 02:30 PM
I used the HUD in my C5s all the time, but as said, some use it, some don’t. It is something that you can do if you find the parts.
Old Oct 22, 2020 | 02:37 PM
DDaaryl's Avatar
DDaaryl
Never use mine. If I was ordering the car new it is not an option I would pay extra for.
Old Oct 22, 2020 | 04:03 PM
djmlax89's Avatar
djmlax89
On a 99 your IPC should be hud capable, so you wont have to worry about replacing that. The install itself is fairly simple, just cut out a pre-marked section of the dash pad, install the bezel and mount the HUD in the vehicle. I recently did the conversion on my 97 (little more involved with replacing the cluster, transferring mileage, etc) but overall not a bad job to do. The hardest part will be locating a quality HUD to use, you may end up having to disassemble and repair the mirror tabs.
Old Oct 25, 2020 | 05:14 PM
Bgrimes's Avatar
Bgrimes
Cruising
Tha is for all the replies. Still searching for one but not a major priority. Thanks again
To HUD install
