C5 OEM Rotors/Pads
Old Oct 24, 2020 | 03:49 PM
Sean_emory's Avatar
Sean_emory
Default C5 OEM Rotors/Pads
Are they available anymore? Want to keep the car original looking if possible. If not what’s the closest thing?
Old Oct 24, 2020 | 05:08 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Yes, still available.
No, no one is going to be able to tell the difference between an OEM rotor and an aftermarket one. Not worth the premium, IMO.
Old Oct 25, 2020 | 10:02 AM
knewblewkorvette's Avatar
knewblewkorvette
These are the best bang for your buck:
https://www.ebay.com/itm/Front-Rear-...53.m1438.l2649
Old Oct 25, 2020 | 11:18 AM
Fcar 98's Avatar
Fcar 98
Original rotors are junk. There are many more options for rotors that look original.
Old Oct 25, 2020 | 11:58 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Old Oct 25, 2020 | 12:10 PM
wdcraig's Avatar
wdcraig
Last year, I wanted to keep the OEM look of solid rotors when the time came to replace my brakes.
Here's an interesting read on drilled and slotted vs solid rotors:
https://www.turnology.com/tech-stori...yths-shall-we/
Anyway, to answer your question; I searched on Amazon for AC Delco rotors for the C5 and I and managed to scrounge the solid rotors for all four corners. I recall I had to go to two or three different vendors; but found what I was looking for. Good luck.
Old Oct 25, 2020 | 01:25 PM
Hary Gahtoe's Avatar
Hary Gahtoe
Default Smoke Em If Yah Got Em
Devils advocate :
The suggested rotor/pad set may be decent but OP did ask for OEM not cross drilled
Nothing wrong with conventional solid rotors and pads. GM Engineers spent alot time and $$'s designing them.
Counterpoint is, I use drilled rotors. Not ebay cross drilled rotors though.
Big takeaway from C5 rotors selection should be the factory rotors and eBay slotted/cross drilled are built for a low cost.
Problem being is that most eBay cross drilled rotors are made from Chinese lower cost metals. Unless they're made with the more expensive and heat rejecting High Carbon steel, your rotors will crack emanating from the holes drilled in the rotors.
All depends on what your priorities are. Cost, performance, longevity safety.
Old Oct 25, 2020 | 03:17 PM
o2bnkc's Avatar
o2bnkc
I second that. BrakeMotive is the best deal for brakes, bar none.
Old Oct 25, 2020 | 06:06 PM
Stingroo's Avatar
Stingroo
BrakeMotive also makes solid rotors:
https://www.ebay.com/itm/For-Chevy-C...cAAOSw4R1dG2xe
The pads suck for anything other than street driving, though. Fair warning.
Old Oct 26, 2020 | 11:59 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
For a quality rotor that performs well and looks like OR I would suggest the Centric premium brand rotors and for pads I would suggest the Carbotech 1521 pad low dust performs like OE and 100% made in the USA.
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Oct 28, 2020 | 02:17 PM
grinder11's Avatar
grinder11
I assume by junk you mean for HPDEs? Because mine have been on for 20 years/115,000 miles. No warpage. Been through the Smokey, Rocky, and Grand Teton mountains, Going to the Sun Hwy, etc. No issues. Not drilled or slotted, they are as delivered by GM. But I realize HPDE events tax them heavily. Only HPDE events I've done, and quite a few times, is drag racing, 1/4 mile only.....
To C5 OEM Rotors/Pads
