I was reading a review on the Z06 and I thought I read that they use leaf springs for suspensions. Why would they do that, when, assuming I remember correctly, coil-over springs provide better response and handling? :eek:
Leaf springs -- like the kind found on live axel cars and trucks -- are composed of multiple leaves held together with u-bolts, THese leaves have to be greased occasionally to minimize the friction of the leaves moving with respect to each other.
In comparison to these kinds of leaf springs, coil overs have lower resistance, and thereby, greater sensitivity.
However, the Vette transverse leaf spring is a monolithic spring; nothing moves, nothing causes excess friction. Therefore, this kind of leaf spring does not loose the sensitivity that the conventional leaf spring looses.
In comparison to the standard suspension setup, coil overs only have the advantage of ease of corner weighting and multiplicity of spring rate choices (dozens versus ~3).
