Hazard switch...now what
Old Nov 7, 2020 | 06:23 AM
Mike1072's Avatar
Mike1072
6th Gear
Default Hazard switch...now what
Hello C5 family!
So...I recently took the plunge and replaced my hazard switch in the dash due to a buzzing turn signal. Not that I have to tell anyone here, but that job was NOT fun! But I got it done with the help of YouTube & other helpful c5 owner hints.
Anyway, now when I use the turn signal, it ‘hyper flashes’ all the time, like there is a bulb out. It does this with both left and right signaling. I’ve checked all the lights and they all work. Hazards work normally as they should. Thoughts on why this happens? It’s kind of annoying to be at a light and hear that thing click away... Thanks in advance!!
2000 FRC owner
Old Nov 7, 2020 | 06:41 AM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
Hyperflash harness under the dash and your problem will go away.
Amazon Amazon
Old Nov 7, 2020 | 07:16 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Why install a hyperflash harness when all he did was replace the hazard switch?
Old Nov 7, 2020 | 07:30 AM
Stingroo's Avatar
Stingroo
Because it will fix his problem of.... wait for it.... hyper flash.
Old Nov 7, 2020 | 07:39 AM
Adwest52's Avatar
Adwest52
Correct me I am wrong but Isn't the harness used to cure hyperflashing due to the installation of LED bulbs? I replaced the hazard switch in my car and didn't have any hyperflash issues afterwards.
Old Nov 7, 2020 | 07:46 AM
Stingroo's Avatar
Stingroo
That's the main reason why people install it, but if you read this thread you can find more data:
https://www.corvetteforum.com/forums...h-failure.html
Hyperflash harness will fix his problem. That's why there's one in my car even without LED bulbs.
Old Nov 7, 2020 | 10:55 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Plus the bypass harness blinker activation sounds so much more refined without the OEM klak-klak noise
Old Nov 7, 2020 | 01:49 PM
dbgoodwin's Avatar
dbgoodwin
the only thing I hate about my hyperflash harness is that I lost the OEM old school flasher sound
Old Nov 7, 2020 | 01:50 PM
Stingroo's Avatar
Stingroo
Same actually. lol
Old Nov 8, 2020 | 09:04 AM
bjones7131's Avatar
bjones7131
Like the OP said Why would he get hyperflash if he has new switch and all lights work and I assume no LEDs. I had a signal light out and Hflash and switch was bad as well, replaced both and no more issues. I am thinking the switch could be bad even though it is NEW. When I replaced mine I left it hanging under the dash for a week or so until I was sure it worked and then put it back in its place. GO figure
Old Nov 8, 2020 | 09:47 AM
No reason that I know of for the lights to hyper flash unless you have LEDs or a bad new switch. Good luck getting this resolved - hate to see you have to tear the dash apart again.
Old Nov 8, 2020 | 09:51 AM
Adwest52's Avatar
Adwest52
Shouldn't have to have a hyperflash harness just because the switch was replaced. Didn't need one from the factory and the lights flashed just fine.
Old Nov 8, 2020 | 03:03 PM
jackthelad's Avatar
jackthelad
That's why we should always test things before spending time re-assemblng. You never know whether a replacement part is good or bad until you try it.
Old Nov 8, 2020 | 03:22 PM
Stingroo's Avatar
Stingroo
So what you're telling me is, you didn't read the thread I posted.
I have no horse in this race. Install the harness and be done or keep futzing around with junk switches. Not my car.
Old Nov 8, 2020 | 03:52 PM
Adwest52's Avatar
Adwest52
No, I did read it but I always like to find out why things don't work the way they are intended to work.
Old Nov 14, 2020 | 07:15 AM
Mike1072's Avatar
Mike1072
6th Gear
Thanks to all for your feedback! Hyper flash bypass purchased, although I agree I figured based on feedback the hazard switch replacement was ‘root cause’...apparently not! At least when I did the hazard switch, I waited to install an MGW shifter at same time to minimize the dash pulling reps!
Old Nov 14, 2020 | 08:36 AM
rjacobs's Avatar
rjacobs
I did a bunch of research on this the other night because the car I just bought has had occasional no signals....
Everybody says first step is the hazard switch. Only problem I have with that is it seems that there are not any actual GM switches available and everything is aftermarket. Ive had poor luck with aftermarket electrical parts.
The next stuff is the signal relay and the flash relay... appears to be two separate relays under the dash... I couldnt find anybody who had actually changed them or if its even possible because everybody jumps straight to throwing a "hyper flash bypass" in because it bypasses the signal relay and "fixes" the problem.
So it seems you fixed the switch(unless you got a bad aftermarket switch) and then you probably(or originally) had/have a bad relay and will remedy with the hyper-flash relay setup... which isnt a bad option and proven to work.
Old Nov 14, 2020 | 08:57 AM
TXGS507's Avatar
TXGS507
As stingeroo said.... Hyperflash bypass... done.
Old Nov 14, 2020 | 09:33 AM
Sids04's Avatar
Sids04
Even better, I bypassed the stupid hazard switch and put in a standard flasher. Pretty simple fix.
To Hazard switch...now what
