Tires
Okay. Cool. Glad we cleared that up.
Motor Trend https://www.motortrend.com/cars/chev...t-test-review/
“Our best results came from the ZR1 with its optional ZTK Track Performance package ($2,995), which replaces Michelin Pilot Super Sport ZP (run-flats) with grippier Pilot Sport Cup 2 ZP tires.”
Car and Driver https://www.caranddriver.com/feature...ning-lap-2018/
Class: LL4 | Base Price: $129,505 | As-Tested Price: $141,485
Power and Weight: 755 hp • 3669 lb • 4.9 lb/hp
Tires: Michelin Pilot Sport Cup 2 ZP, F: P285/30ZR-19 (94Y) R: P335/25ZR-20 (99Y)
Road and Track https://www.roadandtrack.com/new-car...-specs-photos/
"That's 950 lbs pushing down the back, and to complement that, the optional ZTK Performance Package also includes a front splitter with carbon-fiber end caps, Michelin Pilot Sport Cup 2 tires (instead of the run-flat Super Sports), and specific chassis and Magnetic Ride Control tuning for greater cornering speeds. Plus the bucket seats, naturally."
https://corvettestory.com/2019-Corve...horsepower.php
Wheels, Tires
Wheel Size
Front: 19 inch x 10.5 inch
Rear: 20 inch x 12 inch
Tire Size
Front: P285/30ZR19
Rear: P335/25ZR20
Tires
Michelin Pilot Super Sport run-flat (standard)
Michelin Pilot Sport Cup 2 (ZTK)
And especially tell Chevrolet.
From the 2019 Corvette Sales Brochure:
(see below attachment extracted from the brochure)
Last edited by Route99; Nov 19, 2020 at 02:39 PM. Reason: Remove bold face print used in magazine article
We have 18"/19" wheels and use Michelin Pilot Sport A/S Plus ZP (run flat) tires. I do not find them to be hard or noisy. They are a very good all-around tire. Are there other tires with more traction? Yes. However, how many drivers really get to even 7/10s of their tire's ability?
Like you were mentioning, we use our C5 for many longer trips (800-1500 miles), and not uncommonly, are driving late into the evening. I would prefer not to be sitting on the side of the road waiting for AAA to come; or with traffic zipping by, leaning over my car pumping a fix-a-flat type glue into the tire and then topping it off with compressed air.
Interestingly, a 2019 Corvette ZR1 comes with run flat tires. Of course, those tires ONLY support 0-60 in about 3 seconds; top speed of 210+ mph and pulling over 1.2 Gs on track!
And at the risk of being repetitive, the last two times I had a flat tire, it was from hitting some debris on the road that I was unable to avoid. In BOTH cases, the debris put a cut the sidewall of the tire. This was because I saw the debris at the last moment, and cranked on the wheel, therefore avoiding running directly over the object with the tread of the tire, but catching it with the sidewall. So to all of you who advocate an air pump, patch kit, and or can of "slime", how do you propose to repair an inch long cut in the sidewall of the tire? Fortunately for me, those two incidents didn't happen with a car that didn't have a spare tire.
Just my $0.02 worth.............
They aren't worth neutering the responsiveness of your car, IMO.
One thing to consider is if you plan on driving long distances, try and buy a tire from a chain shop of some kind. That way you shouldn't have trouble finding a replacement. You're going to have a hard time finding a chingchong online tire in the middle of nowhere compared to say a Goodyear, Firestone, Michelin, etc.
). Ride is much better, and so is grip, without runflats. Even with runflats, if you're on the trip you speak of, you're still going to have to take time out from the trip, and buy a new tire somewhere, because runflats are good for only 50-200 miles, MAX. So, as mentioned previously, go with a good name brand. If budget allows, I'd go with Michelin or Goodyear, but that's just me. Continental and Goodrich make a very good tire, too. Hope this helps......
I have the A/S 3 tires and have a couple issues that make me never want to buy them again.
First off, they are noisy as hell in my '16 coupe. I'll be trying to put sound baffling in the trunk, but I don't have high hopes.
The second issue I have is if you hit a pothole, there is a good chance you will split the sidewall. I've gone through 3 already.
Never and issue with the factory tires.
Since I daily drive my car, I need an all season tire, but when I split another one of these A/S 3's, I will switching brands.
