C5 Passenger Rear Marker Light
Old Dec 13, 2020 | 11:34 AM
Richard Hyland's Avatar
Richard Hyland
3rd Gear
Default C5 Passenger Rear Marker Light
Any advice on how to install a rear passenger marker light on a C5. It doesn't look like there is enough room to get my hand and a ratchet in there at the same time to tighten the speed nuts.
Old Dec 13, 2020 | 12:02 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
I use a box end wrench. Pretty tight spot for sure.
Old Dec 13, 2020 | 12:18 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
Use a box end gearwrench. They work really well in tight spots. Also it's a little more work but removing the fender liner makes it ultra easy to get to.
Old Dec 13, 2020 | 12:56 PM
grinder11's Avatar
grinder11
Pull the tail light assembly out for whichever side you're working on. I just put a new 194 bulb in the drivers side of my '00 Vert. No problems.....
Old Dec 13, 2020 | 03:39 PM
Floridasky's Avatar
Floridasky
St. Jude Donor '15
Couple small pieces of double faced tape works perfect.
Old Dec 13, 2020 | 06:13 PM
lewislgZ06's Avatar
lewislgZ06
NCM Lifetime Member
St. Jude Donor '18 thru '26
It’s a tight area to work in for sure. The passenger side was most difficult. I think I spent about 30 minutes on the passenger side and 5 on the drivers.
I don’t recall the size but like others said just use a box wrench and turn as much as you can and readjust.
I have the ratcheting wrenches which would have helped, but my set didn’t have that size, of course.
Old Dec 13, 2020 | 10:30 PM
You can go in through the rear outboard tail light and have access to the side marker light housing. Or easy access with the fender liner removed as mentioned.
To C5 Passenger Rear Marker Light
