headlight motors $300+ mistake
Old Dec 18, 2020 | 06:13 PM
6Gxray's Avatar
6Gxray
Cruising
Default headlight motors $300+ mistake
llllllllllllllllllllllllllllllllllllllll
Old Dec 18, 2020 | 06:37 PM
Fast one's Avatar
Fast one
Hooking up the positive first shouldn't cause any damage. No current will flow with the ground disconnected.
Old Dec 18, 2020 | 06:41 PM
6Gxray's Avatar
6Gxray
Cruising
when i hooked the ground up and i seen the spark i knew i just screwed up
Old Dec 18, 2020 | 06:43 PM
6Gxray's Avatar
6Gxray
Cruising
i did not explain well enough i hooked the battery up just put the positive on first
Old Dec 18, 2020 | 07:06 PM
jdmvette's Avatar
jdmvette
Night Owl for life
That sequence shouldn't do anything like you discribe ¯\_(ツ)_/¯
I've put positive cable on my battery on first all the time
Maybe you touched positive to negative??
Old Dec 18, 2020 | 07:12 PM
Fast one's Avatar
Fast one
It's normal to see a small spark when the second cable is attached.
Old Dec 18, 2020 | 08:28 PM
walleyejack's Avatar
walleyejack
there must be more to it than just that.. hooking p up first would do nothing, They either touched each other, or put the postive on the negative post mabye
Old Dec 18, 2020 | 11:07 PM
FX VETTE's Avatar
FX VETTE
Negative is always the last on and the always the first off, I don't get it.
Old Dec 18, 2020 | 11:13 PM
Mickeyrx70's Avatar
Mickeyrx70
Old Dec 18, 2020 | 11:24 PM
Smoken1's Avatar
Smoken1
He was told that in the Tech section before he started this thread
Old Dec 19, 2020 | 12:35 AM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I don't believe it matters electricly which cable is connected first. It is good practice to take negative off first and connect it last. If you have a wrench on the positive cable with the negative cable on, and you accidentally hit any metal you will have a nice electric welder and it will ruin your day.
Old Dec 19, 2020 | 01:00 PM
Since OP deleted his original post, .
To headlight motors $300+ mistake
