Any Battery charger experts?
Old Dec 22, 2020 | 04:41 PM
royal flush's Avatar
royal flush
Default Any Battery charger experts?
For the longgivity of a 12 volt battery--Better to have a charger with a Float mode of about 13.20 volts OR a charger-maintainer that fully charges than shuts off until battery falls to 12.80 volts than turns back on to a full charge-turns off again-on and on--or both OK?
Old Dec 22, 2020 | 04:45 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I wouldn't consider myself an expert. However, if it were my car I'd go with the charger-maintainer option. Although both should be fine.
Old Dec 22, 2020 | 05:19 PM
royal flush
There both charger-maintainers--just operate different
Old Dec 22, 2020 | 06:30 PM
Get yourself either a Deltran Battery Tender Plus or a Ctek model - both work well to keep your battery topped off and in shape.
Old Dec 23, 2020 | 01:08 AM
jim993's Avatar
jim993
I have had my C5 on this generic CarQuest battery maintainer 24/7 excpt on the road or track for 10 years so far. It keeps battery voltage up around 13 volts, does not let the battery drop in voltage more than about 0,1 volts while connected. I installed wiring to the fog light cove on the passenger side for easy connect/ disconnect.
Old Dec 23, 2020 | 10:25 AM
choyt's Avatar
choyt
Not an expert but I've been using a C-tek for about 6 years with the same AC Delco battery with no issues.
Old Dec 23, 2020 | 12:00 PM
knewblewkorvette's Avatar
knewblewkorvette
CTEK, Deltran, or Optima. You can't go wrong with any of those choices. I happen to own all three plus a Schumacher tender.
Old Dec 23, 2020 | 04:37 PM
dooscoop32's Avatar
dooscoop32
I have owned a Deltran 4-bank Battery Tender for years. The original battery in my 2004 Corvette lasted 10 1/2 years thanks to it. I use it constantly on 4 different vehicles and have never had a problem with it.
To Any Battery charger experts?
