battery tender
Old Dec 25, 2020 | 06:59 AM
Dallasfool's Avatar
Dallasfool
Default battery tender
purchased a ever start battery tender awhile back, went to connect it, red cable on positive black on negative, tender is reading cables crossed, so i put red on negative black on positive, now reading that it is charging? is it still safe to use? or take it back? 2004 corvette
Old Dec 25, 2020 | 08:07 AM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I would try one other car first - just to be 1000% sure the unit is defective. If so, take it back.
Cheers!
Old Dec 25, 2020 | 10:20 AM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
If it ain't right take it back.
Old Dec 25, 2020 | 11:19 AM
6spdg37s's Avatar
6spdg37s
did you hook up the permanent terminal connection? I have an issue with that on my C5 right now. Not sure if it is because i broke the negative ring terminal off and put my own on.
I did it the same as every other c5 I had, positive to the main 12v positive under hood and neg to battery neg.
but it flashes red / green
Old Dec 25, 2020 | 02:30 PM
Sunwarrior's Avatar
Sunwarrior
Take it back, swap it
Old Dec 25, 2020 | 03:18 PM
If it does not work properly when connected the way it is supposed to, take it back and get another one.
Old Jan 3, 2021 | 11:32 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Coming late to the party but if you end up taking the Battery Tender back, I would consider getting a CTEK. Lots of discussion and good debate on the Forum about the Tender vs CTEK. Do a search for detailed info but I believe the CTEK is a “healthier” choice. It is not only state of the art charger but also helps to maintain your battery. Like I said do a Sear h.
Old Jan 3, 2021 | 12:23 PM
c5BlackBeauty
Lifetime Member
To battery tender
