Replacement Speakers for Bose C5
Old Dec 29, 2020 | 03:41 PM
LSgoBRRR's Avatar
LSgoBRRR
Default Replacement Speakers for Bose C5
Amazon seller kept me waiting almost a month for the ROEM-VET1 bose adapter only to cancel the shipping label. It was already overpriced and I can't even find another one. I already have my Joying unit from China so now I've got to look into speaker replacements.
Does anyone have any recommendations? Brand, sizes? They don't have to be super duper audiophile speakers but they should sound about as good as the current bose unit and be easy to install/fit properly.
Old Dec 29, 2020 | 03:47 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
PM sent...
Old Dec 29, 2020 | 04:05 PM
SeeFiveZee06's Avatar
SeeFiveZee06
Cruising
I have the same question - and am also curious if there are crossovers or some type of amplifier in the doors, between Bose head unit and Bose speakers, that need to be bypassed/removed when replacing either the speakers, head unit, or both?
I was going to replace OEM head unit with a single DIN Sony high powered (built in amp) head unit, but Crutchfield says it won't work with the "amplifiers in the doors".
Old Dec 29, 2020 | 04:14 PM
LSgoBRRR's Avatar
LSgoBRRR
Yeah the bose unit has separate amps that powers the door speakers (the large ones not the tweeters) inside the door speaker housing, without the adapter they won't work.
Old Dec 29, 2020 | 04:17 PM
SeeFiveZee06
Cruising
Great - does this unit do the same as the unit mentioned in the initial post above?
Amazon Amazon
Old Dec 29, 2020 | 04:34 PM
LSgoBRRR's Avatar
LSgoBRRR
Great - does this unit do the same as the unit mentioned in the initial post above? https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I'm not sure but there were base model speakers and the bose system was an upgrade, so this looks like it's for the base GM setup.
Old Dec 29, 2020 | 04:58 PM
Clancy209's Avatar
Clancy209
Call Crutchfield they are very good. they will help with questions
Old Dec 29, 2020 | 10:05 PM
JMG2's Avatar
JMG2
Moderator
there are dozens of posts on this. I did hertz in the rear, audiofrog and subwoffers in the door.
New install, with new 8" kicker subs in Door - CorvetteForum - Chevrolet Corvette Forum Discussion
I used this DD head unit-- I HIGHLY recommend it, not expensive, and super thin:
consider this DD headunit if you're doing an upgrade... - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Dec 30, 2020 | 06:41 AM
Corvette#2's Avatar
Corvette#2
I think it does, because the description says :
  • R. A. P. (Retained Accessory Power) function is retained
  • Retains the amplified door woofers with the use of a differential line converter
That's the issue with the Bose system, the woofers in the doors have their own built in amps which prevents you from just doing a simple head unit swap. So this seems to fix that. But I'm not 100% since my car has the PAC ROEM-VET1 adaptor that a stereo shop used on the install with a new head unit. But I can say the new head unit made the stereo sound better, even while reusing the crappy factory Bose speakers. (I just wanted a working stereo, wasn't trying to go high end)
To Replacement Speakers for Bose C5
